Fixing bent steering wheel? #934944
02/22/11 02:13 PM
02/22/11 02:13 PM
St. Clair Shores, Michigan
bigsbigelow Offline OP
Does any one know of any place that fixes bent steering wheels? If not, how did you do it? I was thinking of making a clam shell device of the same diameter as the wheel and torquing it around the wheel to get it round. Then (leaving the clam shell on) just pounding it against a flat surface to get it square.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Fixing bent steering wheel? [Re: bigsbigelow] #934945
02/22/11 04:19 PM
02/22/11 04:19 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I don't know if I would trust a 'bent' steering wheel. The metal has already been stressed, and may 'break'
on impact, rather then bend once fixed. Half of a steering wheel stuck in your sternum would not be a happy picture.
Re: Fixing bent steering wheel? [Re: Montclaire] #934946
02/22/11 04:42 PM
02/22/11 04:42 PM
Good point. You have me thinking.
Re: Fixing bent steering wheel? [Re: Montclaire] #934947
02/22/11 05:40 PM
02/22/11 05:40 PM
Toronto, ON
ehbody Offline
ehbody  Offline
Toronto, ON
+1
Shawn 70 AAR
Re: Fixing bent steering wheel? [Re: ehbody] #934948
02/22/11 06:13 PM
02/22/11 06:13 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
FWIW, back in the mid-70s my Dad cut a 62 Fury in pieces so he could haul it off in a stepside pickup.
I remember him swinging repeatedly with a sledgehammer on the steering wheel -- and it took some serious hits to flatten it into the dash. (we were poor and hillbilly and Dad didn't have special tools like a steering wheel remover)
Based on the 'clamshell tool' originally described:
A steering wheel close enough that you could consider massaging back into shape isn't going to become an eggshell because of the massaging.
Re: Fixing bent steering wheel? [Re: ehbody] #934949
02/22/11 11:52 PM
02/22/11 11:52 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
+1
+2
Not just for yourself, but if the car/wheel ever gets passed on to someone else.
Mo' Farts
Moderated by "tbagger".
Re: Fixing bent steering wheel? [Re: Grizzly] #934950
02/23/11 06:52 PM
02/23/11 06:52 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Just straighten it and run it, its not going to break with a little bend, its not that brittle. Tim
