Ford Bullitt Wheels on 8.75 rear end
#932421
02/19/11 04:57 PM
02/19/11 04:57 PM
Posts: 833 Marietta, GA
Joatha
Marietta, GA
With my 8.75 rear not installed, I was doing some measuring and checking. I have a set of Mustang Bullitt wheels (which I love the look of) and mounted them up on the rear while it was on sawhorses. I noticed that the center register didn't clear the wheels (which I sort of expected). Its just barely too small for the axle. Is the way to fix this to grind out the wheel? Or should I take a little off the axle?
If I do this to the wheels, will it be OK to just use a stone head on the end of a drill and remove material? Or do I want to get a machine shop to remove a specific amount so that it will sit flush? Or do I take the axles to a machine shop and have them remove a specific amount?
Just making sure I do this right.
1966 Barracuda
1968 Barracuda convertible
1930 Ford Model A (soon to be hemi equipped)
2006 Dodge 3500 4X4 CTD Quad Cab
Re: Ford Bullitt Wheels on 8.75 rear end
[Re: Yancy Derringer]
#932426
02/20/11 12:00 AM
02/20/11 12:00 AM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
The wheel register on the axle steps up to the brake drum.
Machine the (outer) wheel register, NOT the (inner) brake drum pilot.
[Re: AndyF]
#932429
02/20/11 01:41 PM
02/20/11 01:41 PM
Joatha
Marietta, GA
The brake register for a Ford is 2.525". So, I should be able to turn it down to that and it should work. There is a small lip in the wheels that is likely there to clear the Ford register.
I don't have any 10x2 (or 2.5) drums yet for this. Anyone know how thick the drums are?
1966 Barracuda
[Re: AndyF]
#932431
02/21/11 10:07 AM
02/21/11 10:07 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
the bullit rims have a chamfer on the wheel, some 1/8" spacers will be enough to fit over the mopar rear axle flange w/o any machining...
ease of use, if you can find a small bore ridge reamer (say for a briggs & stratton), you should be able to shave .030" off of the wheel bore to fit the axle....
[Re: patrick]
#932432
02/21/11 01:15 PM
02/21/11 01:15 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
We've run the Mustang wheels for years by just taking a 2" drum roll sander to the rims. We do the rims so we can interchange them between different cars; doing the axles works, too. I run 16" Pony rims on my Caravan and a friend has 3 Intrepids or 300M's with GT or Bullet rims. The 114.3 metric rims are the same as 4.5" bolt pattern, so you'ld be surprised how many rims actually fit the older cars. Really makes the tire monkeys at Belle Tire scratch their heads, too!
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: patrick]
#932433
02/21/11 08:46 PM
02/21/11 08:46 PM
Joatha
Marietta, GA
There's a part of me that wonders if I could knock enough off if I just took a metal file to the edge of the axle registers and filed them off evenly instead of taking them to a machine shop. It shouldn't require much material coming off.
1966 Barracuda
