Re: Question for Holley Dominator gurus [Re: dmking] #928415
09/10/11 11:58 PM
09/10/11 11:58 PM
It sounds like you need to lean down the idle and part throttle side of the primarys and set the pump circuit up to pump less and in a shorter peroid of time, just like I do I've been fighting the rich condition at part throttle on all of my Dominator carbs, I'm trying to lean them down using my LM1 wide ban, sneaking up on it slowly
Re: Question for Holley Dominator gurus [Re: sanger440] #928416
09/11/11 09:56 PM
09/11/11 09:56 PM
Wisconsin
MagnumExpress Offline
Wisconsin
I did not read all the posts, so someone already mentioned this, but I had the same issue. I fixed it by installing 1 heat range hotter spark plug. I have never had the problem again. Just my 2 cents
#9 in the world. 2006 IHRA Super Rod
2010 IHRA Div.5 Hot Rod Champion
