Help picking a cam
#927459
02/13/11 01:05 AM
02/13/11 01:05 AM
Posts: 302 Middle of the US
Verga
Middle of the US
Need some help picking a cam for a low budget build. .040 over 440, Keith Black pistons, 6 pack rods. 10 to 1 compression. Street Dominator Intake, 800 Holley Double Pumper, 346 heads that are stock except being freshened. 2 inch headers. Car should weigh around 3800 lbs. I have a 9.5 inch converter that should flash close to 4 thousand RPMs. 3.55 or 4.10 gear. Im figuring the headers are probably a little big, but that is all I have at the moment. Due to a shortage of funds, Im stuck with an off the shelf grind. Looking for recommendations for both a solid and a hydraulic. If anybody has built a similar motor, ET, MPH and cam used would be great also!!! BTW, Im not interested in the VooDoo grinds, anything else is fine. Long story.
Re: Help picking a cam
[Re: Verga]
#927462
02/13/11 04:01 AM
02/13/11 04:01 AM
DaytonaTurbo
Manitoba, Canada
I run a voodoo cam, no problems. I would have suggested a voodoo 60304 would fit the bill nicely.
[Re: Verga]
#927464
02/13/11 02:38 PM
02/13/11 02:38 PM
Posts: 1,456 oklahoma
forphorty
oklahoma
Since you said budget build, i'm guessing you may be using the stock rockers. If so, i've had good luck with the old Comp 292 Magnum hyd. .030 440 8.5 comp, 906s pocket ported when i was 20yo and didn't know what i was doing(still don't), Torker,750dp, 10 in GER stalled about 3800, 3.23s, 28 x9 slicks, 68 Satellite street car all steel except for 6 pak hood. 12.35 at 106, 1.69 60 ft. Cam has been in for about 25 years and hasn't gone flat yet in spite of me not always changing the oil as often as i should. Car sometimes sits for months and then might be driven almost every day for a while.
[Re: forphorty]
#927466
02/13/11 03:23 PM
02/13/11 03:23 PM
Verga
Middle of the US
Ive actually got some 1.6 rockers.
What RPM do you shift that cam?
[Re: Verga]
#927467
02/13/11 05:00 PM
02/13/11 05:00 PM
forphorty
oklahoma
[Re: Verga]
#927470
02/13/11 10:21 PM
02/13/11 10:21 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Narrow down to solid or hydraulic first?
Lets say a solid.
Looks like the Comp 292 should work if I go with a hyd.
There are way better cams now then the old cc292. A buddy of mine built a very similar deal last year, had an old comp 280 (230@50) and went to the comp 284xe and gained around a half second. This was in a fully stock body '68 Bee, ended up going 11.6X .
I have had good luck with the.528 mp solid too, but there are better grinds now worth investigating.
[Re: RemCharger]
#927471
02/13/11 11:13 PM
02/13/11 11:13 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Not sure on "way better" part......I laugh everytime a new grind is the shiznit, and the old stuff is junk. My junk runs decent (11.30s)with pretty old lobes (Comp TL lobes).....Thinkin about having Dwayne grind me a cam with the super duper new stuff for a comparison.
Well lets see... the XE284 grind has 10 more degrees on the intake side than the 280, 16 more on the exhaust..., not to mention the extra .25 ish more of lift. The XE grind has 13 more degrees at .200 than the 280. So yeah, it should be quicker. I dont think that is a good comparison.
The XE274 would be a better comparison. 3 degrees more at .200 than the 280. Same intake duration at .050.
The XE284 and 292Mag would be a much better comparison, for the larger grinds. I'll throw it out that in a heavy car the 292 takes the XE284......
Im not a fan of split duration cams, and after talking at length with Dwayne, I understand why.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: RemCharger]
#927473
02/13/11 11:26 PM
02/13/11 11:26 PM
Von
NE Oklahoma
All I was trying to get at is don't buy a sh!++% old cam. I subscribe to the theory that there is no such thing as too big of a cam/conv/gear. Of course this is the wrong forum for that, but I must explain where I come from.
I agree on the cam/conv/gear thing, but not that the 292 is a sh$$$ old cam. Ive known forphorty for a long time and his stuff runs hard...with hardly anything. Ask the all knowers if his stuff should run 12.30s with... gasp....3.23s...
[Re: Von]
#927475
02/13/11 11:42 PM
02/13/11 11:42 PM
RemCharger
Sk. Canada
The only reason I would disagree with that is there are better cams now. The lift on that is .501(?)...And with the bending and deflection of stuff, its under 500 lift. Don't get me wrong, I've seen those cams work too.
[Re: RemCharger]
#927476
02/13/11 11:56 PM
02/13/11 11:56 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
A lot of guys optimize those MP cams to run better times with the rest of the combo on the engine. It's a hit or miss game, what could be the cam holding power back could actually be tuning problems, wrong intake, exhaust restrictions, too heavy car for combo, etc. or visa-versa. EVERYTHING has to work together to produce good power!! And yes, not everybody wants to run an MP cam, there ARE many other choices.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: HYPER8oSoNic]
#927477
02/14/11 12:18 AM
02/14/11 12:18 AM
Von
NE Oklahoma
[ A lot of guys optimize those MP cams
Who said anything about a MP cam??
[Re: RemCharger]
#927478
02/14/11 12:21 AM
02/14/11 12:21 AM
Von
NE Oklahoma
Please define better....and why more lift is needed with stock castings?
Ive already discussed the same subject with Dwayne...
[Re: Von]
#927479
02/14/11 12:36 AM
02/14/11 12:36 AM
RemCharger
Sk. Canada
True, it will run real nice with a stock cam.
[Re: RemCharger]
#927480
02/14/11 12:38 AM
02/14/11 12:38 AM
Von
NE Oklahoma
with a stock cam.
Ya, how do stockers run so well with sub 500 lift.
[Re: HYPER8oSoNic]
#927482
02/14/11 12:41 AM
02/14/11 12:41 AM
Von
NE Oklahoma
Relax man!
[Re: Von]
#927483
02/14/11 12:52 AM
02/14/11 12:52 AM
RemCharger
Sk. Canada
with a stock cam.
Sorry, I didn't realize the OP is building a Stock/SuperStock car. Must be reading to fast.
[Re: RemCharger]
#927485
02/14/11 01:12 AM
02/14/11 01:12 AM
Von
NE Oklahoma
[Re: Von]
#927487
02/14/11 01:31 AM
02/14/11 01:31 AM
HYPER8oSoNic
Desert Tracker
You got me ROTFLMAO... http://www.moparts.org/Tech/Archive/bb/Lobe.htmlDang RB and MP old technology....Sure wish they would have tested some of the newer shiznit grinds. Oh wait...they did... Here, I'm throwing it back at ya!! The update (test page), works WELL for 3500-3600 pound B-bodies. The poster has nearly TWO-TONS of car. The performance of those cams DO NOT relate to his CAR WEIGHT!! Look, I'm not knocking the newer cams, but you fail to realize that WEIGHT effects the perfomance. You can make horsepower, but torque is needed to move the MASS effectively. Want to run HARDER, lighten the car!! THEN, pack in the horsepower. BTW, the RACER BROWN cam looked pretty good, probably the most driveable one of the bunch!
[Re: HYPER8oSoNic]
#927490
02/14/11 01:56 AM
02/14/11 01:56 AM
Von
NE Oklahoma
How do the cams NOT relate to car weight??? Look at the torque #s the RB cam put up.
I think you are not seeing my problem with some of the comments on this thread,and most other cam threads. To make the statement that "this cam, or that cam sucks, is out dated, is a SHi445 pos, etc", is totally ridicoulous.
As you said its all in the combination......I agree that most cam related problems are due to other issues, (compression, converter, advance curve, tuning, etc)
But, as in forphorty's case (whose car is no lighweight, 3600 and change I believe) if I asked 100 people what his car runs with no compression, 3.23s, very little headwork, and a high mileage motor to boot, most generally the answer would be "That cam is too big, it will be a flippin hound" or something along those lines.
Too many blanket statements thrown out on this board that are at best half true.
[Re: Von]
#927491
02/14/11 01:57 AM
02/14/11 01:57 AM
RemCharger
Sk. Canada
with a stock cam.
Peace Out!!!
Could you at least post the whole article? I didn't see the part about the sub 500 lift cams.
Andy is a serious asset to the mopar community, I'm honoured to see he recommends the same hydraulic as I do
Glad we can finally agree and move forward.
[Re: RemCharger]
#927492
02/14/11 02:05 AM
02/14/11 02:05 AM
Von
NE Oklahoma
You hittin a crack pipe? Where did I say they tested sub 500 lift cams....
Not so fast there, pundit. Looks like the old school crap RB cam took the honors.... Something to the lines that they could tell the shiznit Comp hyd didnt have the low end that the RB cam had and the dyno backed it up. Hmm, split duration had less torque than the POS old school RB, where have I heard that before?
[Re: Von]
#927493
02/14/11 02:25 AM
02/14/11 02:25 AM
RemCharger
Sk. Canada
BTW, which cam company is high lighted in the sources box??
I'm not going to dwell into Andys article as he would tell you ,which I'm sure you know, every combination is different. I said I like the XE284 over the old comp 292/501. You got agitated. Too bad we couldn't have a dyno shootout in that motor and see.Probably wouldn't end up being that far from each other.
[Re: RemCharger]
#927494
02/14/11 02:28 AM
02/14/11 02:28 AM
Von
NE Oklahoma
[quoteI said I like the XE284 over the old comp 292/501. You got agitated. Actually said that the 292 was a shi%%^ old cam. But,no harm no foul. Too bad we couldn't have a dyno shootout in that motor and see.Probably wouldn't end up being that far from each other.
Now back on track, so to speak...
[Re: Von]
#927495
02/14/11 02:33 AM
02/14/11 02:33 AM
RemCharger
Sk. Canada
[Re: Verga]
#927498
02/15/11 02:13 PM
02/15/11 02:13 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
10:1, 2" headers, 4000 stall and 4.10s.
Yep, put a .557 MP cam in it and let it eat.
Rich H.
Esse Quam Videri
[Re: HYPER8oSoNic]
#927499
02/16/11 01:04 AM
02/16/11 01:04 AM
HYPER8oSoNic
Desert Tracker
First of all Andy produced a GREAT article as always, very informative and detailed. Major props to him!! Next is the issue about weight and power. As a simple recap, I looked at the highest torque producing cam that had driveability manners. Thats why I look at car weights vs. cam lift/duration. All I'm saying is that the heavier the car, the more torque has to be placed in the engine power range at lower side and midrange (2500-5000 rpm). The car can horsepower up to 6000-6500 maybe, but it's the effective torque at the lower scale which MOVES the mass and the horsepower maintains the momentum.
[Re: HYPER8oSoNic]
#927500
02/16/11 02:11 AM
02/16/11 02:11 AM
Von
NE Oklahoma
[quote. All I'm saying is that the heavier the car, the more torque has to be placed in the engine power range at lower side and midrange (2500-5000 rpm).
Agreed. Heavy car =grind it on a 108 and put in real early, 100-102 and let it eat....
[Re: Von]
#927507
04/30/11 11:18 PM
04/30/11 11:18 PM
HYPER8oSoNic
Desert Tracker
No, there are NO blanket statements here, just the human nature of each individual who HAS a certain combo on their thinking it's the best. Not all MOPARS that rolled off the line are 100% exactly alike!! They vary in weight, trim packages, body styles, engine/drivetrain, etc. So the thought of one cam fits several combos is seldom and for the combo to run alike is far and few, unless they are 100% "clones".
