is this cam bearing properly installed? #923313
02/07/11 09:57 PM
02/07/11 09:57 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Its the outer cam bearing that goes towards the timing chain.
I see that it is not driven all the way in and that it is blocking the groove that I suspect serves a purpose to oil the timing chain sproket.
Is it OK or should it be pressed farther in until the groove is not blocked?
see pic
Re: is this cam bearing properly installed? [Re: domingo] #923314
02/07/11 10:26 PM
02/07/11 10:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
see pic
Isnt that the oil hole I see in the block... if so
the bearing should be on top of it with the hole in
the bearing lined up on it.... otherwise your dumping
ALOT of oil doing nothing(not counting the loss
of pressure and not oiling that cam journal)
EDIT
I see now thats BB so if the oil hole in the bearing
lines up with the block hole, should be it
Re: is this cam bearing properly installed? [Re: MR_P_BODY] #923315
02/07/11 10:40 PM
02/07/11 10:40 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes, it is a big block and the bearing hole lines up with the block oil hole. Its just that groove that makes me wonder....
I mean I suspect it is there for something and the bearing is blocking it. I imagine it must be there to oil the surface where the cam mates to the cam sproket and then it slings the oil to the timing chain....right or not?
Should I just leave it as is and not worry about it?
Re: is this cam bearing properly installed? [Re: domingo] #923316
02/07/11 10:41 PM
02/07/11 10:41 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
It will probably lube just fine where its at. But the factory installed cam bearing/block I have sitting here its pushed back about halfway.
A block that had the same front cam bearing installed by a local shop has in pressed in all the way to the bottom of the slot.
So Half way or All the way, your call. Or for less oil for the chain gear sprocket, your judgement. I myself would give that slot some clearence. mike
Re: is this cam bearing properly installed? [Re: Sport440] #923317
02/07/11 11:12 PM
02/07/11 11:12 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I just took a file and opened up the bearing a little where the groove is at so that the passage isnt blocked.
I didnt want to touch the bearing and drive it farther in....I dont want to missalign it.
Thanks!!!
Re: is this cam bearing properly installed? [Re: domingo] #923318
02/07/11 11:29 PM
02/07/11 11:29 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Good idea, mike
Re: is this cam bearing properly installed? [Re: domingo] #923319
02/07/11 11:42 PM
02/07/11 11:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks!!!
You should be fine... there's a fair amount of oil
that spills out the front of the bearing to lube the
chain and gears
Re: is this cam bearing properly installed? [Re: MR_P_BODY] #923320
02/08/11 12:30 AM
02/08/11 12:30 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks for the advice!
