TorqueFlite 727-How Much Slippage #917104
01/30/11 02:58 PM
01/30/11 02:58 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I've got a 727 and 2.94 gears. The car doesn't pull like a 440 should. I'm planning a gear swap for this year. I was playing with a speed/rpm calculator, and according to calculations my transmission is roughly 80-85 percent efficient right now. At 70 mph (verified with a GPS), im turning 3000 rpm. It's a stock, regular low stall factory converter. I understand that the torque converters can wear out so to speak over time, but this transmission also behaves oddly and runs through the gears way too quickly. (There is no time between 2nd and 3rd at part throttle) The line pressure adjustment is correct and the throttle pressure linkage is adjusted correctly.
My question is, how much slippage should there be with a stock converter? I would think only about 5-10 percent.
Re: TorqueFlite 727-How Much Slippage [Re: GTX MATT] #917105
01/30/11 05:21 PM
01/30/11 05:21 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
so you think you have about 20% slippage ?
How is your ATF quality ?
Re: TorqueFlite 727-How Much Slippage [Re: GTX MATT] #917106
01/30/11 06:16 PM
01/30/11 06:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it's shifting 2-3 that quickly chances are the TP linkage is NOT adjusted correctly.
Re: TorqueFlite 727-How Much Slippage [Re: John_Kunkel] #917107
01/30/11 06:38 PM
01/30/11 06:38 PM
Amherst,NY
challengermike Offline
Amherst,NY
TV linkage is not set correctly.it wont stack stick if its correct.
Re: TorqueFlite 727-How Much Slippage [Re: challengermike] #917108
01/30/11 08:02 PM
01/30/11 08:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
x3 on the TP linkage not being right .
Also 5 - 10% slippage on a factory convertor ??
Re: TorqueFlite 727-How Much Slippage [Re: dOc !] #917109
01/30/11 08:30 PM
01/30/11 08:30 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Its turning color pretty quickly and the transmission is generating clutch material and metal like mad. It will need to be rebuilt for sure.
The throttle pressure linkage is all the way back at full throttle. I checked the lever on the transmission and it pulls it all the way at full throttle. I even had a friend look at it who rebuilds transmissions and used to be a certified Chrysler transmission technician and he reassured me that its set correctly.
I'm trying to figure out what my slippage should be after a rebuild.
Re: TorqueFlite 727-How Much Slippage [Re: GTX MATT] #917110
01/30/11 09:18 PM
01/30/11 09:18 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
NORMAL driving .... other than WOT ... with no-load ... should be virtually NO slippage.
You have a trans that is coming-apart.
Re: TorqueFlite 727-How Much Slippage [Re: GTX MATT] #917111
01/30/11 09:30 PM
01/30/11 09:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
sounds like the trans is slipping if it is generating clutch and metal , that is not normal. as far as your linkage being all the way back at full throttle that is not properly adjusted. get out your service manual and adjust it as it says in there .
