Page 1 of 3 1 2 3
Trans kickdown linkage update w/ pics #915898
01/28/11 04:16 PM
01/28/11 04:16 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
what speed would you consider as a factory high stall? Manufacturer just said that a standard replacement, which is the only one they carry is 1800-2000. What would be a factory high_stall speed rating?
thanks
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Factory hi_stall converter [Re: roe] #915899
01/28/11 05:11 PM
01/28/11 05:11 PM
scratchnfotraction Offline
about that amount,IMO
will depend on engine input and results vary
you have the balance fly wheel so a stock high stall TC for a 904 is what you want
unless you want/need more stall,then it what you pay for and aftermarket
Re: Factory hi_stall converter [Re: scratchnfotraction] #915900
01/28/11 05:36 PM
01/28/11 05:36 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Big blocks were a 10.5 inch converter with a 2800 stall, if I recall correctly. If this is going behind a smallblock, find out what they used on the AAR/TA motors or behind a 340 demon.
Re: Factory hi_stall converter [Re: Montclaire] #915901
01/28/11 08:38 PM
01/28/11 08:38 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
As an example, from the 1975 FSM:
318 w/904, 10.75", 2125rpm - 2425rpm stall
318 w/727, 11.75", 1725rpm - 2025rpm stall
360-2 or 360-4, 10.75", 2300rpm - 2600rpm stall
360-4 H.P., 10.75", 2200rpm - 2500rpm stall
400-2 or 400-4, 11.75", 1875rpm - 2175rpm stall
400-4 H.P., 10.75", 2400rpm - 2700rpm stall
Note: There are three 440-4 engines listed, not denoting any difference other than converter size. Two with the same larger converter size have different stall speeds. I can only assume that the one with the higher stall speed is behind an H.P. engine, but through a printing error it is not shown as such. There should be one in the chart. I would also assume that the 440 with the small converter would also most certainly be an H.P. application. Why two different converters behind H.P. engines?
440-4, 11.75", 1975rpm - 2275rpm stall
440-4, 10.75", 2600rpm - 2900rpm stall
440-4, 11.75", 2100rpm - 2400rpm stall
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Factory hi_stall converter [Re: roe] #915902
01/28/11 08:42 PM
01/28/11 08:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The actual stall speed of the factory hi-stall converters varies with the engine it's coupled to; for example, in the chart below the 727-equipped 318, 340 and 383-4 all used the exact same hi-stall converter.
The 440 didn't get a hi-stall converter until around '75.
Re: Factory hi_stall converter [Re: John_Kunkel] #915903
01/28/11 11:31 PM
01/28/11 11:31 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
ok, thanks a lot guys. I've been pricing a trans rebuild where I supplied the parts, but the most recommended shop near me suggested letting him do the converter in-house so that its covered under their warranty, and he asked me what stall speed I would want. For the car in my sig, 360/904, edelbrock performer intake, 4bbl edelbrock carb (1406 model IIRC) with 8 1/4 rear and 2.76 gears, what stall speed would you suggest. 1800-2000 or say 2000-2200 ish, or even higher. Hopefully in the future I will swap in a 2.94 or even a 3.23 gear at the most, but it won't be for a while, if that matters at all.
I posted a similar question before and the consensus was that a factory high stall would be good for me, but i never asked exactly what that stall speed was.
thanks again
roe
Re: Factory hi_stall converter [Re: roe] #915904
01/29/11 01:58 AM
01/29/11 01:58 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
to build the converter to the proper stall, the shop will need to know your exact cam specs, exact compression ratio, rear tire size (height), maybe a few other things also (you already mentioned your axle gear ratio). If he doesn't ask or care about the above information, he is building something more of a generic converter instead of a converter built to maximize performance. And he should be suggesting a decent auxillary trans cooler also. Cheaper converters in general will slip more and generate more heat than a better built model. So read up and proceed with caution/plenty of information.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Factory hi_stall converter [Re: roe] #915905
01/29/11 02:05 AM
01/29/11 02:05 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Factory high stall would be ok with your combo. Who is building the transmission?
Re: Factory hi_stall converter [Re: GO_Fish] #915906
01/29/11 05:36 PM
01/29/11 05:36 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I understand what you're saying, but I bought this motor from someone already assembled. I'll check the many reciepts I have for any part numbers that may give me more info, but I don't know how detailed that will be. It seems like a pretty much stock rebuild with better intake and bigger carb. It ran perfectly fine in some 87 octane that I had in the tank, even though I run 93 octane, so that makes me think comp ratio and cam are pretty tame, given the really smooth idle and LA heads. It's not really a performance build, just looking to make my daily driver a little more peppy/fun/respectable. Does this info help at all with a recommendation? Right now I'm leaning toward 2000-2200, that sound ok?Cheaper converters in general will slip more and generate more heat than a better built model. So read up and proceed with caution/plenty of information.
Re: Factory hi_stall converter [Re: goldmember] #915907
01/29/11 05:51 PM
01/29/11 05:51 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I haven't made a decision yet, just pricing and getting references right now. The shop I'm leaning towards, Danny's Transmissions, is a little more than the others, but not a crazy amount. I've contacted about 8 shops so far and two of those actually referred me to Danny's.
Re: Factory hi_stall converter [Re: roe] #915908
01/29/11 06:35 PM
01/29/11 06:35 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Okay. Please understand, I'm not trying to be a downer. I just know that the right converter for your package will put a smile on your face every time you mash the gas pedal. And the wrong converter will make your car a dog at which point you will be pulling the transmission again and changing the converter, or worse, you will loose interest in the project and sell it. And there is a lot of area between those 2 extremes also.
2000-2200 sounds reasonable, but is really a roll of the dice with experiences of others here helping to tilt odds to your favor. How much time will you spend operating the engine at or below 2200? If most of your driving is on the highway or at engine speeds above 2200 rpm, you should be okay. If most of your driving is in the city, a 2200 stall could cause a lot of transmission heat from slipping and hurt your gas mileage pretty bad also.
Re: Factory hi_stall converter [Re: GO_Fish] #915909
01/29/11 08:10 PM
01/29/11 08:10 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
No you're not being a downer, that's why I started this post, so I can get advice from those with more knowledge/experience with this than me. I dont do an outrageous amount of highway/long distance driving, but with this being my daily driver its the car I use when I do. So even with an auxillary trans cooler you think that will slip too much and cause excessive heat? would the 1800-2000 be better for me?
Re: Factory hi_stall converter [Re: roe] #915910
01/29/11 08:28 PM
01/29/11 08:28 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
excessive heat kills transmissions, so a good trans cooler will help get the extra heat out of the transmission. I'd consider it a must have, cheap insurance. You can even get used ones from the pick and pull. If you find yourself stuck in 20 mph traffic in town, stop and go, and your rpm's are below your stall speed, you can manually shift down to 1st or 2nd gear and hold it there until you get out of traffic, and that will probably increase above your stall speed, but will suck down gas also that way. Whether you choose 1800-2000, or 2000 - 2200, I'd say too close to pick with certainty without specifics on your engine and the rest of the package. The vehicle weight also plays into this. All of my experience is with lighter A bodies, so a B will want a little different stall.
Re: Factory hi_stall converter [Re: roe] #915911
01/29/11 08:29 PM
01/29/11 08:29 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Ok guys, I read back over this post and some similar ones by me and others and have decided to go with the 1800-2000 stall speed, with the engine specs that I can supply him. I will also check my reciepts and see if I can come up with more. I will have a trans cooler aswell. Anyone object to this?
thanks
roe
Re: Factory hi_stall converter [Re: GO_Fish] #915912
01/29/11 08:36 PM
01/29/11 08:36 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
excessive heat kills transmissions, so a good trans cooler will help get the extra heat out of the cooler. I'd consider it a must have, cheap insurance. You can even get used ones from the pick and pull. If you find yourself stuck in 20 mph traffic in town, stop and go, and your rpm's are below your stall speed, you can manually shift down to 1st or 2nd gear and hold it there until you get out of traffic, and that will probably increase above your stall speed, but will suck down gas also that way. Whether you choose 1800-2000, or 2000 - 2200, I'd say too close to pick with certainty without specifics on your engine and the rest of the package. The vehicle weight also plays into this. All of my experience is with lighter A bodies, so a B will want a little different stall.
Re: Factory hi_stall converter [Re: roe] #915913
01/29/11 08:48 PM
01/29/11 08:48 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I always have PTC build converters for my application, but a factory hi stall(which is far from it in fact.LOL) is only about $85.00. So I'd suggest if your on a tight budget just slap a stock or Hi stall factory unit and drive it. If you need another builder option PM me. You still in Gville?
Re: Factory hi_stall converter [Re: goldmember] #915914
01/29/11 09:50 PM
01/29/11 09:50 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
read this a time or two, it may help answer some of your questions. torque converter operation and performance
Re: Factory hi_stall converter [Re: GO_Fish] #915915
01/29/11 09:59 PM
01/29/11 09:59 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Sorry,I don't have any questions. Maybe you mean the OP.
Re: Factory hi_stall converter [Re: GO_Fish] #915916
01/29/11 10:19 PM
01/29/11 10:19 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
good read and good info.
thanks
Re: Factory hi_stall converter [Re: GO_Fish] #915917
02/18/11 04:04 PM
02/18/11 04:04 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
finally got around to looking through some receipts that came with the motor and found something that says 268* duration, and .458" lift with "same as factory 340 cam" written next to it, and "hyper pistons 9:1 comp"
Page 1 of 3 1 2 3
