Page 3 of 3 1 2 3
Re: Factory hi_stall converter [Re: scratchnfotraction] #915938
03/15/11 10:56 PM
03/15/11 10:56 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
looking at the pics,I see you need a mopar throttle adaptor on the carb to get the throttle pin in the correct place
I was able to get everything lined up and working with the current carb setup, but I went ahead and ordered the throttle adapter bracket so that I can change the placement of the kickdown linkage return spring (dont know what else to call it), the one that returns the kickdown linkage to starting position. No one had the throttle adapter in stock so I ordered it and it should be here on thurs
2 flat bars for bellcrank to carb adjustment to start with first
does not look like much adjustment is left on the band with only 1/2" of threds,but it might have one last time on it
hopefully there is one last adjustment on it, it may actually be about 3/4" left on the threads. Either way, Im hoping
I cant make out the TPV lever or the gear selctor lever to well. looks like they are mixed pieces and cobbled together some how
I havent had any problems with the gear selector. At one point the gear selector was off slightly. I would have to go slightly past Drive in order for it to move into drive, so I just adjusted it at the adjustment point on the linkage. I'll get some pics of the gear selector linkage as well when I grab some of the corrected kickdown linkage.
I got 1/2 of what you need if your guy needs some parts to go with his
its like playing I spy with your pics..post more plez
more pics soon to come
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Factory hi_stall converter [Re: roe] #915939
03/16/11 04:33 AM
03/16/11 04:33 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
TPV linkage sitting against throttle pin correctly with return spring. Everthing funtioning properly but still waiting on mopar throttle adapter bracket
Re: Factory hi_stall converter [Re: roe] #915940
03/16/11 04:39 AM
03/16/11 04:39 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
New TPV lever with slider block mounted from bottom. Still dont have the spring that should be in front of the slider block.
Re: Factory hi_stall converter [Re: roe] #915941
03/16/11 04:42 AM
03/16/11 04:42 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
another angle
Re: Factory hi_stall converter [Re: roe] #915942
03/16/11 04:46 AM
03/16/11 04:46 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
The kickdown rod how it sits after I made my adjustments with the bends
Re: Factory hi_stall converter [Re: roe] #915943
03/16/11 04:51 AM
03/16/11 04:51 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
You asked about my gear selector linkage so here is the connection at the steering column
Re: Factory hi_stall converter [Re: roe] #915944
03/16/11 04:55 AM
03/16/11 04:55 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Rod with the adjuster on it that comes down from the steering column
Re: Factory hi_stall converter [Re: roe] #915945
03/16/11 04:57 AM
03/16/11 04:57 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Gear selector connection at trans
Re: Factory hi_stall converter [Re: roe] #915946
03/16/11 05:01 AM
03/16/11 05:01 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Last one
Re: Factory hi_stall converter [Re: roe] #915947
03/16/11 09:19 AM
03/16/11 09:19 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Even though you're well on your way to getting this straightened out, here's an excellent source for factory advice on adjustments.
http://www.imperialclub.com/Repair/Lit/Master/index.htm
Go toward the bottom of the page for the more recent bulletins.
The print literature will open with just a plain ole web browser.
Re: Factory hi_stall converter [Re: roe] #915948
03/16/11 09:45 AM
03/16/11 09:45 AM
scratchnfotraction Offline
thats mucho better
when you get the throttle adaptor it will move it back an inch or so
you may then need to rebend the rod as needed,if it then whats to move the flat bar slot back it ok,you will just use the 2 bars to make that up and all the adjustment will be down on the slide block
the spring that pulls the TPV linkage forward should be on the throttle pin and hooked to the hole in the end of the long 1-piece rod
the shifter linkage looks good
very well done
you look ready for the band adjustment and road test now that the linkage is close enuff to adjust
Re: Factory hi_stall converter [Re: scratchnfotraction] #915949
03/16/11 11:29 AM
03/16/11 11:29 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
thats mucho better
very well done
Yeah, I've got the linkage adjusted to where I want the shifts. I'll post the shift speeds and rpms after the band adjustment and fluid/filter change.
I got a lot done recently with the car. It turned out that the fuel sending unit was shot so I replaced that yesterday as well, now my fuel gauge works and is accurate. I will also be doing a complete flush and replace of the brake fluid in the system. The front brake hoses were replaced when I put on new calipers, and the rear hose and wheel cylinders will be replaced before I flush the system. I replaced the brake booster/master cylinder about a week or two ago. I put on a new tranny mount as the old one was shot. Everything is coming along nicely.
I may even get to some cosmetic stuff like swapping in my side marker lenses, and making a new set of lenses for my parking lights.
roe
Re: Factory hi_stall converter [Re: roe] #915950
10/14/13 06:24 PM
10/14/13 06:24 PM
cv70chall Offline
cv70chall  Offline
I think I have the wrong kick-down bar installed. The linkage at the carb (just behind it) won't stand upright because it seems as if the bar is too short. I also need to find/ buy a kick down spring.
Any ideas as to where I might be able to get the right bar and spring?
I have a 360-904 combo with a 4BBL setup.
(See pix)
Thanks!
Page 3 of 3 1 2 3
