Re: when to put screws in the rims for slicks
[Re: bigdad]
#915382
01/28/11 10:37 PM
01/28/11 10:37 PM
Quicktree
Guy on the bullet goes 5.14 and has never used screws or bead locks ..
lets argue some more
geez, what does that have to do with running tubes with out screws
[Re: Quicktree]
#915383
01/28/11 10:43 PM
01/28/11 10:43 PM
Posts: 34,828 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
The topic at hand was slick / screws
Never was tubes, slicks, screws
And , it was also do tires turn and it turned into the tires come off the rims without screws
[Re: bigdad]
#915384
01/28/11 10:50 PM
01/28/11 10:50 PM
Quicktree
well if you had read my post I replied to another post about somebody running tubes with out screws. I have run slicks with out screws but never with tubes in them. although I do think you get a better result with screws and safer to boot.dosn't matter how fast people have gone with out them. take a look at how many people have posted problems with out them. it only takes opnce to have a bad day.
[Re: bigdad]
#915386
01/28/11 11:30 PM
01/28/11 11:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I will stand by this
I think people run screws in sidewalls ..
Just because
Do they help performance .. ??
No idea
is is safe ???
There is NO rule that says you need to
When NHRA or IHRA demands it and there a long, long history that says they will never ..
No need
Do what ever floats your boat... I KNOW my tire cant pop of the beads.... but then again I run tubes and alot dont believe the tube helps... AGAIN to each their own
[Re: MR_P_BODY]
#915388
01/28/11 11:44 PM
01/28/11 11:44 PM
Quicktree
Just because
No idea
is is safe ???
No need
[Re: poppaj]
#915389
01/28/11 11:47 PM
01/28/11 11:47 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I changed to a new set of rear rims last year and was going to put screws in them ( I run my slicks tubeless and always had used screws)The guy at M/T told me Not to put the screws in, he showed me on the new rims they are now putting a safety bead to keep the tires from braking off the outside bead. Look at the new rims there is indeed a hump on the inside. He said the old spun style rims like super tricks definitly needed screws but not the new designs.
Easy on the dry hops boys !!
[Re: bigdad]
#915391
01/28/11 11:59 PM
01/28/11 11:59 PM
Quicktree
who does that? I have to admit I did a few in the old days but it's been over 20 years ago.
[Re: bigdad]
#915393
01/29/11 12:17 AM
01/29/11 12:17 AM
MR_P_BODY
It means , tires in 2011 are not like they were in ...
And possibly , we have grown to the era that we no longer need to run screws in our rims
Hence , dry hops
Again , there is NO RULES to run screws in the beads
AGAIN.... what ever floats your boat... its your car you do with it as you please... I'll take care of mine
[Re: poppaj]
#915394
01/29/11 12:22 AM
01/29/11 12:22 AM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
I bought a car with rims like this on it. But it's only on the outside bead. Guess what, all the rims screws were broke off from the previous owner, lol.
[Re: MR_P_BODY]
#915395
01/29/11 12:33 AM
01/29/11 12:33 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Hence , dry hops
It is not about floating my boat
Please , tell me where the rules say you have to run any screws in the rim ?
I just want to abide by the rules
[Re: bigdad]
#915397
01/29/11 12:40 AM
01/29/11 12:40 AM
MR_P_BODY
Hence , dry hops
Guys run bead locks also when not needed... is it for safety.... it is for me.... I KNOW my tire isnt popping off the bead on the hit or if my car gets loose off the line going sideways
[Re: MR_P_BODY]
#915398
01/29/11 12:45 AM
01/29/11 12:45 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Hence , dry hops
I would like to hear an engineer tell us just how many lbs of air pressure holds a tire to the bead
I am not but I'm sure it will amaze you
[Re: MR_P_BODY]
#915400
01/29/11 01:04 AM
01/29/11 01:04 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Sorry but I have seen tires come off the rims when the car was sideways ... your not going to see that occur on mine ... as to what pressure it takes... it s a matter of which has the greater pressure... is it the air pressure inside it or the side loading of the tire going sideways.
You better start screwing those front tires too
then
LAST COMMENT FOR ME ON THIS TOPIC
STAY SAFE FELLAS
