60ft times vs tire height
#911047
01/22/11 09:03 PM
01/22/11 09:03 PM
Posts: 1,365 elmira ny
hp340nos
elmira ny
i was wondering if my 60fts would improve with a shorter tire height,88 dakota 3340# 418cid, 9.7 compression, pump gas small block stroker,about 470 hp,driven to the track, 727 reverse pattern lba tranny.ptc 10" converter, flashes 4200, 8 3/4 3.91 posi,stock front /rear shcks with cal/trac bars, m/t drag radial 295/65-15.1st time at track with new motor it ran 7.31@94.5 with a 1.64 60ft.im thinking about going to a m/t drag radial 275/60-15 or a 325-50-15 which are 28"tall instead of 30 like the current 295-65-15?i was thinking the tall tire was hurting my off the line gearing?
Re: 60ft times vs tire height
[Re: hp340nos]
#911048
01/22/11 10:24 PM
01/22/11 10:24 PM
Yes, shorter tire will definitely help your 60 foot.I tried to go as small up front as possible without the car looking ridiculous.
[Re: MR_P_BODY]
#911050
01/22/11 11:18 PM
01/22/11 11:18 PM
Quicktree
Granted those are tall tires for your gear but better shocks would also help you
the shorter tire also reduces contact patch and may cause traction issues if the car is not set up well. so it could actually slow you down if you can't hook.
[Re: hp340nos]
#911053
01/23/11 02:28 AM
01/23/11 02:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Also think of it this way... its cheaper to change a gear than it is to buy a set of tires.... tires about $450 and a gear and set up is $320 or less
[Re: hp340nos]
#911060
01/24/11 05:32 AM
01/24/11 05:32 AM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
i was wondering if my 60fts would improve with a shorter tire height,88 dakota 3340# 418cid, 9.7 compression, pump gas small block stroker,about 470 hp,driven to the track, 727 reverse pattern lba tranny.ptc 10" converter, flashes 4200, 8 3/4 3.91 posi,stock front /rear shcks with cal/trac bars, m/t drag radial 295/65-15.1st time at track with new motor it ran [Email]7.31@94.5[/Email] with a 1.64 60ft.im thinking about going to a m/t drag radial 275/60-15 or a 325-50-15 which are 28"tall instead of 30 like the current 295-65-15?i was thinking the tall tire was hurting my off the line gearing?
I think your combo would be helped with a shorter tire BECAUSE the combo should have a taller gear in it.
BUT ... if the car is geared correctly .... I don't see how a shorter tire would help 60 foot times. Now reaction times ... that is another story.
[Re: dOc !]
#911061
01/24/11 06:07 AM
01/24/11 06:07 AM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
it would also look better w/ shorter rear tires IMO
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
