{{{ Tunnel Ram Vacuum Question }}} #906880
01/16/11 10:09 PM
01/16/11 10:09 PM
Lehigh Acres, Florida
rickstershemi Offline OP
OK....can I tap directly into the tunnel ram plenum for the PCV Valve or is it better to go to the carb or should I be pulling from both carbs t'd to the pcv....?????
The reson is it would be a clean direct route from the t-ram to the pcv
Rickster
Re: {{{ Tunnel Ram Vacuum Question }}} [Re: rickstershemi] #906881
01/16/11 10:15 PM
01/16/11 10:15 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
either place is fine, whatever looks cleaner would be the best route. me persoanly would drill and tap under the plenum to hide it.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: {{{ Tunnel Ram Vacuum Question }}} [Re: rickstershemi] #906882
01/16/11 10:18 PM
01/16/11 10:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Rickster
Its all the same vac under the throttle blades...
put it anywhere that looks good
Re: {{{ Tunnel Ram Vacuum Question }}} [Re: MR_P_BODY] #906883
01/16/11 10:20 PM
01/16/11 10:20 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Vacuum hoses are ugly. I'd tap the rear of the plenum to keep the hose as out of sight as possible.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: {{{ Tunnel Ram Vacuum Question }}} [Re: bigtimeauto] #906884
01/16/11 10:22 PM
01/16/11 10:22 PM
Kinda what I thought...and under the plenum sounds like a good idea.....Thanks
Rickster
Re: {{{ Tunnel Ram Vacuum Question }}} [Re: rickstershemi] #906885
01/16/11 11:12 PM
01/16/11 11:12 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i wouldnt run a PVC
Re: {{{ Tunnel Ram Vacuum Question }}} [Re: sixpackgut] #906886
01/16/11 11:15 PM
01/16/11 11:15 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
If its a street car i would, race car with a power adder i wouln't
Re: {{{ Tunnel Ram Vacuum Question }}} [Re: sixpackgut] #906887
01/16/11 11:41 PM
01/16/11 11:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i wouldnt run a PVC
me neither, isn'6t that something plumbers use
Re: {{{ Tunnel Ram Vacuum Question }}} [Re: sixpackgut] #906888
01/17/11 12:00 AM
01/17/11 12:00 AM
i wouldnt run a PVC
Me either, but I will run a PCV...
Rickster
Re: {{{ Tunnel Ram Vacuum Question }}} [Re: rickstershemi] #906889
01/17/11 12:26 AM
01/17/11 12:26 AM
i wouldnt run a PVC
Rickster
Helps keep condesation moisture out of the motor water mixed in oil makes acids
Re: {{{ Tunnel Ram Vacuum Question }}} [Re: Quicktree] #906890
01/17/11 12:38 AM
01/17/11 12:38 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i wouldnt run a PVC
ooops
