Re: "Don't ask me how I know..."
#893
07/27/03 02:40 AM
07/27/03 02:40 AM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
...lug nuts need to be tightened on new aluminum wheels after 100 miles
adjusting transmission fluid lines at the radiator on a car that's running and has a Flex Fan can scar you for life
a girl can get pregnant on the pill
a Ford engine can spin a bearing at idle in New York City rush-hour traffic
it costs $650 to get a pickup towed 350 miles across West Texas when the cat plugs up
the sound a Mag-Lite flashlight makes on a convicted rapist's head
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
[Re: AdamMopar]
#894
07/27/03 04:57 AM
07/27/03 04:57 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
A sure grip, a V8, rain, and a A body will tend to do a abrupt u turn with very little warning.......
...and I drove across the lawn at the local McDonalds from THAT one...
Sticking your hand in the blender will cause the motor to stop and make that annoying "whirring" noise...
Trying to be like Dad @ 5 years old will not stop the gas from going down your throat after sucking on the hose...
Making your own oil pump priming shaft can crack out the top of the pump if it's not straight, and finding where the oil pressure went can take WEEKS!
Assuming the manual trans you just installed has enough fluid in it to go for a quick drive can make the tranny VERY hot and not work anymore. Gosh, those gears are a pretty blue color (as opposed to Petty blue... )
Never assume that breaking the inside bead on a medium truck tire still on the vehicle means you can aim. A 7# hammer glancing into your temple in mid swing can cause an unexpected nap...
The guy across the intersection may not see your bicycle coming at him @ approximately 20MPH and may make that left turn anyhow...
Testing connections on an electric fuel pump while covered in gasoline can give you coveralls that make a cool conversation piece...
Not all vehicles have a clutch safety switch...
And my personal favorite...people frown on being passed by you when they are pulling over for an ambulance!
DAMHIK...
2 Demons...no, not my kids!
[Re: Just Cameron]
#896
07/27/03 12:45 PM
07/27/03 12:45 PM
Hearing the dull thud of a Steering Gear Box dropping on the cement garage floor inches from your left ear is not a sound you'd want to hear twice in your life! Don't ask me how I know this!
[Re: DARTROD]
#897
07/27/03 02:06 PM
07/27/03 02:06 PM
"Never gun the throttle lingage on the carburator when adjusting the idle speed because the manual for your 75 Chevelle says to adjust it in drive. The car will jump the 4x4 chunk of wood you used for a wheel chock with no problem. And if you happen to live across the street from a bluff you could come very close to exploring the woods below if your not hanging on to the steering wheel with your legs hanging out the door while your trying to shift the transmission back into park(it will just keep going).
#898
07/27/03 02:27 PM
07/27/03 02:27 PM
Posts: 9,336 central New Jersey
dbdartman
central New Jersey
Never do this if you're adjusting the idle mix on a 66 Charger, while it's in reverse with the parking brake holding it back. Gun the engine once, & the car moves back about 1'... just enough to stop the car right on... one foot! The only way to get it off? Gun the engine again...!
DAMHIK
[Re: bill_greenwood]
#900
07/27/03 11:07 PM
07/27/03 11:07 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
180+k '81 225 1-vs and moderate grades do not mix, especially in 3500 lb bricks, despite right foot in water pump and in direct in your OD-4 with 3.55 gears out back.
You MUST wait till the thermostat opens on a 225 to attempt even a slight refill. Not doing so will cause coolant to be expelled, ending up everywhere, including the sides of fenders.
Driving '71 Darts in 100+ degree weather sans carpet will make you feel like a cooked turkey, especially if the heater is turned on high to keep temps in check. (The car wasnt mine, my Buddys I helped retreive).
a trans pan filled with black fluid and many shavings does not mean the fluid was never changed, it indeed was. It really means that its even worse than trans coming out of your 1974 Monaco with busted low/reverse band.
Trans swaps on gravel suck if said trans is worse than the one you just pulled out of said 1974 Monaco.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
