Re: Mopar Performance Max Wedge Heads [Re: mr_340] #896408
01/19/11 02:58 PM
01/19/11 02:58 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Thanks for the info... I bought my heads 2 years ago and have been wondering about'm. The motor feels much stronger compared to.. ported to max wedge size 915s it had. But that doesn't mean much.
Re: Mopar Performance Max Wedge Heads [Re: mr_340] #896409
01/19/11 08:09 PM
01/19/11 08:09 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
I also have a set of old 286 Stage I heads. I had them flowed on another bench (homemade deal calibrated with the Superflow laminar flow element from the dyno). Only the intake was flowed as his rig wasn't setup to flow a Mopar exhaust.
Stage I 2.08 Int. Mild Port 134.5 190.5 227 257 280 289
How mild a port? Bowl blend and "shine" job?
Re: Mopar Performance Max Wedge Heads [Re: 6PACMAC] #896410
01/20/11 03:08 AM
01/20/11 03:08 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
I would say it's about an average port job, some enlargement but no welding or epoxy or brass to put it in the wild category. Actually the flow is from two heads ported by different people, but the flow numbers for both were within a few CFM at all points. The orange head was said to be ported by Lee Shephard, but there is no documentation to prove that. The exhaust seats were replaced.
Floyd Lippencott IV
Re: Mopar Performance Max Wedge Heads [Re: mr_340] #896411
02/05/11 09:01 PM
02/05/11 09:01 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
finally got a chance to dig through my notes.
these numbers are for a set of the NHRA version head.....2.08/1.88 valves.
this is one of the newer heads without the freeze plugs in the ends, but it isnt the latest version with the "undersized" chamber.
also, the valves i used were modified in a way which seems to perk up the low lift numbers a bit.
the valves were out of an NHRA stocker head, so i'm not going to get into the details of what was done.
aside form the valves though, this head is right OOTB.
no valve job, nothing.
this head was tested on a 4.250 bore(426 size), instead of the 4.375 i usually test BB stuff on.
28" test pressure, 3/4" thick radius plate air entry.
lift-----I/E
.100--68.4/57.7
.150-110.6/76.4
.200-150.5/96.7
.250-184.2/116.6
.300-208.6/131.4
.350-222.5/145.1
.400-230.0/158.0
.450-241.2/167.9
.500-249.5/177.3
.550-258.1/184.8
.600-265.5/189.0
i have some numbers for the ones with the freeze plugs somewhere. i'll dig around and see if i can find them.
as i recall.......they werent as good as these.
looking at the pics Randy posted, his look like the latest version, which i would expect to be slightly better than the numbers above.
his is the 2.14/1.81 version, and the 2.14 valve should be worth something.
