Master cylinder factory finish #89195
07/15/08 08:35 PM
07/15/08 08:35 PM
Leetonia, OH
R6T8net Offline OP
R6T8net  Offline OP
Leetonia, OH
Typically what was the finish on the master cylinder out of the factory? Black, natural? Application specific?
"Who is John Galt?"
68 Coronet RT LL1 Auto
70 Duster 340 (yea right) FE5 4 SPD, 11.86 @ 114 MPH so far
01 2500 Quad Cab 4x4 Cummins
Re: Master cylinder factory finish [Re: R6T8net] #89196
07/15/08 08:43 PM
07/15/08 08:43 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
It depends on the year and application.
All disc brake master cylinders from '67 to '70 were painted semi gloss black as an assembly; cap, body, bail wire.
The bodies of '67-70 drum brake master cylinders were e-coated black prior to machining, meaning the machined surfaces such as the outlet bosses, piston retainer boss, flange and cap mating surface were bare metal. The caps were plated a thin gold color and the hold down bolt and bracket were dull gray.
From '71 forward for at least a few years both drum and disc were coated a sort of dull, gray phosphate, cap and all. The exception was the '71 hemi disc brake mc which was a carryover from '70 and painted black.
Re: Master cylinder factory finish [Re: Mastershake340] #89197
07/15/08 08:51 PM
07/15/08 08:51 PM
Leetonia, OH
R6T8net Offline OP
R6T8net  Offline OP
Leetonia, OH
Excellent, thanks!
"Who is John Galt?"
