Re: Main bearings
[Re: WBR]
#888523
12/26/10 01:22 PM
12/26/10 01:22 PM
RapidRobert
Replace em for sure. EDIT what do the journals look like?
Re: Main bearings
[Re: RapidRobert]
#888524
12/26/10 01:40 PM
12/26/10 01:40 PM
Posts: 85 europe
WBR
europe
The thing that worries me is, the engine has been driven only for like four quartermile runs, with 11.9 sec time, if it matters. The mains still have original bolts. If i replace them with ARP stuff, will it need to be alignhoned with new bolts?
Street driven, 421 Sb, NA, 9.98/137
Re: Main bearings
[Re: WBR]
#888526
12/26/10 01:58 PM
12/26/10 01:58 PM
RapidRobert
Is the eng out on a stand or are you up under it under the car? (I'm assuming under the car). Unlike rod bolts (cause they locate the cap) you can replace main bolts WO align bore or honing if that ends up being our solution). W this happening so soon can you post some clear close up pics of what we're dealing w? EDIT What eng
Re: Main bearings
[Re: WBR]
#888527
12/26/10 02:13 PM
12/26/10 02:13 PM
Posts: 4,848 Memphis
HemiRick
Memphis
It's normal for bearings to lose the satin new finish and turn shiny after use.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Main bearings
[Re: HemiRick]
#888528
12/26/10 03:01 PM
12/26/10 03:01 PM
Posts: 85 europe
WBR
europe
The engine is on a stand. Theres 2feet of snow so i got the time. I`m about to do some porting to the heads so i figured i could check things so everything would be ready for summer. I lost bearings last summer,after rebuild, i think because main bolts came loose.(???) I had the crank turned and everything seemed ok. After the runs oil pressure dropped some, from 70 to 45 psi, with 20/50 valvoline racing. so something happened? I `m gonna tear it down and check the rod bearings also. What else? I`ll try to get some pics for ya tomorrow.
Re: Main bearings
[Re: WBR]
#888529
12/28/10 01:21 PM
12/28/10 01:21 PM
Posts: 85 europe
WBR
europe
Ok. Here`s a pic of the bearings. They are the three middle ones. Now that i looked at them with better time, i think they look ok. I just got paranoid after last summers problems. The engine is a 360 with 12-1 icon forged pistons and scat I-beam rods, a Lunati ft-cam, and w2-heads. But the oil pressure still bothers me.
Re: Main bearings
[Re: buildanother]
#888531
12/28/10 01:44 PM
12/28/10 01:44 PM
Posts: 85 europe
WBR
europe
Thanks. I`m starting to feel the same way. The crank looks good (and feels) so i think i`m good to go.
Re: Main bearings
[Re: WBR]
#888532
12/28/10 01:45 PM
12/28/10 01:45 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
And it should , what is your clearance ?
Re: Main bearings
[Re: JohnRR]
#888533
12/28/10 02:25 PM
12/28/10 02:25 PM
Posts: 85 europe
WBR
europe
Actually, have to admit i didn`t measure after the last trip to crank grinder. Anyway, The oil pressure was good after i put it together (70+ psi) but dropped after the trip to the strip. If all bearings check out, could it be the oil pickup tube which i found at teardown to be a bit loose at the pump end threads, and suck air threw the threads? What do you guys use for sealant at the threads if any? i thought of a tack weld to lock it to the pump but that won`t seal it all the way.
Re: Main bearings
[Re: JohnRR]
#888535
12/28/10 03:57 PM
12/28/10 03:57 PM
Posts: 85 europe
WBR
europe
Actually those marks on bearings are the original satin finish. The picture doesn`t show it very good. The pick up tube was tight when installed and i was afraid to turn it a whole turn more to get it positioned correctly. I was a bit surprised it was loose, but live and learn. Will plastigage give me a accurate enough measure of the clearances? I`ve heard some like it and others don`t. I used it the first time and should have some left in the shop.
Re: Main bearings
[Re: WBR]
#888536
12/28/10 07:08 PM
12/28/10 07:08 PM
RapidRobert
I am going out on a limb & say that the clearance was way too tight (& maybe the psi dropped when they wiped shiney & clearance increased it). Since the crank looks good I'd get some .001" under bearings or some same size bearings w increased clearance. . No way should they be wiped that shiney in that (brief) amt of use. Sumpin ain't kosher. NPT threads need sealant & w yours being a bit loose use the thickest sealer you can find. Permatex #2 in the toothpaste like tube is good.
Re: Main bearings
[Re: RapidRobert]
#888537
12/29/10 12:50 PM
12/29/10 12:50 PM
Posts: 85 europe
WBR
europe
Thanks. I`ll do the measuring. I think its the only way to get piece of mind. IŽll be back when i get some numbers so we can see if you hit it correctly. Is there a way to check the oilpump itself before installation?
Re: Main bearings
[Re: Dave Watt]
#888539
12/29/10 02:49 PM
12/29/10 02:49 PM
Posts: 85 europe
WBR
europe
No, I have the filter straight. I,ve been using fram filters(ph 43), but been hearing they wouldn`t be that good. Would there be any benefits of using the 90` and being able to use longer filter?
Re: Main bearings
[Re: WBR]
#888540
12/29/10 04:13 PM
12/29/10 04:13 PM
JohnRR
U.S.S.A.
I'm not sure how hard it is for you to get filters where you are but I would ditch that POS fram filter.
Re: Main bearings
[Re: JohnRR]
#888541
12/29/10 04:16 PM
12/29/10 04:16 PM
Posts: 15,548 Norwich CT USA
moparts
Norwich CT USA
Looking at that bearing wear, From that picture it looks very normal to me. Quote:
Was this cold engine to hot engine? What was the idle pressure when hot? Does it go up when you rev it up?
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
Re: Main bearings
[Re: moparts]
#888542
01/01/11 03:48 AM
01/01/11 03:48 AM
Posts: 85 europe
WBR
europe
This was hot engine vs hot. Got me some plastigage and got to measure a few journals. The middle one showed 002 and the front one less than that. So i think clearances have been tight. I think it should be more like 0025 with new bearings. Will see what i find at the rod journals. I asked at the speed shop for 001 under bearings, but he didn`t have any listed on the 0.02 under size. Are there any available or is a trip to the crank grinder my only option to gain more clearance? I also bought ARP main bolts, but they don`t have the provision for a windage tray. What`s my options on that one? And thanks for the help. I really appreciate it!
Re: Main bearings
[Re: WBR]
#888543
01/01/11 10:14 AM
01/01/11 10:14 AM
Posts: 85 europe
WBR
europe
Got the rod journals measured. 0.oo15. bearings looked pretty good. Is this too tight?
Re: Main bearings
[Re: WBR]
#888544
01/01/11 10:57 AM
01/01/11 10:57 AM
RapidRobert
yes too tight. the most critical area (in the oiling system) is providing for the rod journals/bearings. Check w your crank grinder but might not be able to get the clearance you need by polishing. It'll make it out of round. Polishing is more for achieving a smooth finish. Keep searching for the correct oversize bearings you need. Peruse the SB "parts for sale" for a set of the shouldered 4 main bolts you need for the tray and do not use the large washers on the large bolts "if included" w them. there's a set (+ the tray) in there a day or 2 ago for $25 & I'm tempted to grab it myself even tho I dont need it (at the moment) cause the price is right and someday I will! Use flat washers or flat spacers between the tray and the large bolt shoulder to adj the tray height. Also check that the main bolts are not bottoming out
Re: Main bearings
[Re: RapidRobert]
#888545
01/01/11 03:12 PM
01/01/11 03:12 PM
Posts: 85 europe
WBR
europe
I `ll give a call to our local parts supplier. They will know if such bearings are available. otherwise, it`s a trip to crankgrinder once again... Thanks everyone for the help!
Re: Main bearings
[Re: WBR]
#888546
01/01/11 03:48 PM
01/01/11 03:48 PM
RapidRobert
Let us know how it turns out
Re: Main bearings
[Re: RapidRobert]
#888547
01/04/11 06:25 AM
01/04/11 06:25 AM
Posts: 85 europe
WBR
europe
There is not such bearings available in that undersize. (.02+001). But the speedshop guy is also a known enginebuilder and he felt that i should be fine with clearances i have. But if i wanted more clearance i could take some from the backside of the bearings with a 400 grit paper. How does that sound to ya? Could i be ok with what i have?
Re: Main bearings
[Re: WBR]
#888549
01/04/11 10:45 AM
01/04/11 10:45 AM
Posts: 591 Champion City
The Sphinx
Champion City
.0015 to .003 is the spec. You are not too tight.
Re: Main bearings
[Re: The Sphinx]
#888550
01/04/11 03:15 PM
01/04/11 03:15 PM
Posts: 85 europe
WBR
europe
Ok. So i should be good to go as it is. i`ve heard that from several now. that would be good money wise. Would be so many places to spend that money...
Re: Main bearings
[Re: WBR]
#888551
01/04/11 06:47 PM
01/04/11 06:47 PM
RapidRobert
for a daily driver .0015 would not be too tight but for a 1/4 miler I would definitely want more but I dont want to cause you undue worry & good luck & stay in touch w us.
Re: Main bearings
[Re: RapidRobert]
#888552
01/04/11 11:31 PM
01/04/11 11:31 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
maybe I'm getting too old or loosing it but I always thought if you want more clearance on a bearing you would go 1-2 thou. over size. If you cut a crank 10 thou. under standard size then you would install a 10 thou. under bearing .......forgetting clearence for the moment. If your crank is standard and you need more clearence wouldn't you have to install an over(standard size) bearing to give you the desired clearence. Maybe our termology is different here in Canada.
Re: Main bearings
[Re: RapidRobert]
#888554
01/05/11 03:04 AM
01/05/11 03:04 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
A good rule of thumb is .001" of bearing clearance for each inch of crank journal. So .0025"-.0030" on the mains and .0020"-.0022" on the rods. If the engine is going to be run warm quite often, you can go tighter, or just run a HV pump and do a little oil system massaging (smoothing, enlarging passages). I don't really recommend doing it (though I have in a pinch), but I've used worn out scotch brite (green) on the face of the bearings to gain clearance. Keep clean solvent running on it while you run the SB across the bearing. I hold the bearing half in one hand and scotch brite on my thumb of the other. I cover half the bearing and count the number of strokes. Flip the bearing, do the other half. Then I flip it again and lightly go across the whole bearing face. You won't gain much, but if you're close it will work. And if you go to copper, you've gone too far. Kind of a last ditch effort sort of thing. The best thing to do is take the block to the machine shop and have the main housing bores opened up and the big ends of the rods opened up as well. As for filters, the PH series fram filters have no place on anything performance. The TG filters are closer to a WIX type filter and I'm not afraid of them as much. Is the plug under the #5 main cap that directs oil to the filter still there? That'll cause low oil pressure.
