Re: Adjusting the valvetrain
[Re: 70RT Charger]
#88793
07/15/08 10:08 AM
07/15/08 10:08 AM
RapidRobert
pull the valve covers,spark plugs & a 1&1/4" socket/breaker bar on front dampener bolt. adj each pair of rocker arms when it's companion cyl is on rockover. rockover is when both rocker arms on the OPPOSITE(companion)cyl are both moving & are at the same height. split the firing order 1-8-4-3-6-5-7-2 & put the first 4 numbers on top of the last 4 IE the(1) will be over the (6) so when #6 is on rockover you adj #1 & when #1 is on rockover you adj #6 then go to the next pair.
