RWL tires: Radial T/A vs Firehawk vs Sportsman S/T?
#885793
12/22/10 10:24 PM
12/22/10 10:24 PM
Posts: 2,309 Tomorrow.
Damned67
Tomorrow.
Hi All, Looking to buy some 15" RWL tires for my '67 Plymouth. Will be going on 15x7s on the front and 15x8s on the rear. I'm in Oz, and have very limited access to such tires. The Firehawks and Radial T/As are very limited size wise, hence the odd sizes. So, choices are: BF Goodrich Radial T/A 225/70/15 and 255/70/15 ($840 for the four) Firestone Firehawk Indy 500 215/65/15 and 235/60/15, or 235s all round ($800 for the four) Mickey Thompson Sportsman S/T 225/60/15 and 255/60/15 ($880 for the four) As you can see, there's litte difference in price between them. So they're all fair game. I've read great reveiws of the Firehawks compared to the T/As, but would prefer something wider than the 235/60/15. The Sportsman S/Ts have better choices regarding sizes, and have a higher speed rating, but can't find too many reviews/opinions on them. I'm leaning towards the Sportsmans, but would like to have some user opinions on them? It should be noted that these are simply 'street' tires, I'm also getting a pair of drag radials for track duty. As such, tire width for performance may not be the deciding factor. Of those three choices, what would you choose? Cheers!
Re: RWL tires: Radial T/A vs Firehawk vs Sportsman S/T?
[Re: Damned67]
#885794
12/22/10 10:35 PM
12/22/10 10:35 PM
Posts: 17,515 Las Vegas, NV
6bblgt
Las Vegas, NV
assuming '67 b-body?
I'd stick with the 15x7s on the rear, none of the tires listed need more than 7" & the 8" wheels backspacing would have to be "dead nuts" to fit properly in the '67s quarters. Is the car mini-tubbed?
BF Goodrich Radial T/A wheels 6" front & 7" rear 225/70/15 and 255/70/15 ($840 for the four) 225/70/15 is tall, is the car sitting high in the front? Is there a smaller (215) front tire available?
Firestone Firehawk Indy 500 wheels 7" front & 7" rear 215/65/15 and 235/60/15, or 235s all round ($800 for the four) 235 = small rear tire Is there a larger (245) rear tire available?
Mickey Thompson Sportsman S/T wheels 7" front & 7" rear 225/60/15 and 255/60/15 ($880 for the four) 225 = small front tire - too short!!
If the your choices are limited to the above tires, The Firestones would "fit" best. The Radial T/As would be my choice, but clearance may be non-existent on the front corners.
[Re: topside]
#885797
12/22/10 10:51 PM
12/22/10 10:51 PM
Damned67
Tomorrow.
With the Sportsman S/Ts, I can also source 225/70/15s and 235/60/15s. The rims I'll be buying (again, very limited in selection) are 15x7 with 4" BS and 15x8 with 4.5" BS. I know people have fit 275/60/15s under the 67 B-bodys (although, sometimes with difficulty, hence my choice to stick with 255s), so I'm simply assuming that a 255/60 on a 15x8 with 4.5" BS will fit??? I've been wrong before.... This is why I'm asking these questions, so I can be pointed in the right direction. It's an investment that I can really only afford to make once, so I need to get it right. Cheers!
[Re: 6bblgt]
#885801
12/22/10 11:48 PM
12/22/10 11:48 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Jason, I pulled the Satellite out of the garage to take some pictures so you can contrast to my setup. As I've told you, I wish I had gone a little bigger with my tires. My combo is 245/60-15's on 15x7's in back and 225/65-15's on 15x6-1/2's in front. 255's will definately fit on 7" rims. Cant immagine they'd be too much different on 8's.
Here come some pics.....
[Re: StealthWedge67]
#885802
12/22/10 11:50 PM
12/22/10 11:50 PM
StealthWedge67
Puyallup, WA
Fronts: again, these are 225/65's. I think 225/70's would be perfect.
#885803
12/22/10 11:51 PM
12/22/10 11:51 PM
StealthWedge67
Puyallup, WA
Rears: 245/60's. Witdth is good, I just wish they were taller. I think 245/70's would be the perfect choice.
#885804
12/22/10 11:52 PM
12/22/10 11:52 PM
StealthWedge67
Puyallup, WA
rear fenderwell clearance: these are perfectly squared up with equal clearance on inside and out. rims have 4-1/4" bs.
[Re: 6bblgt]
#885805
12/22/10 11:54 PM
12/22/10 11:54 PM
Damned67
Tomorrow.
BF Goodrich Radial T/A wheels 6" front & 7" rear 225/70/15 and 255/70/15 ($840 for the four) 225/70/15 is tall, is the car sitting high in the front? Is there a smaller (215) front tire available? Car isn't sitting high. Sadly, nothing smaller than the 225/70/15
Firestone Firehawk Indy 500 wheels 7" front & 7" rear 215/65/15 and 235/60/15, or 235s all round ($800 for the four) 235 = small rear tire Is there a larger (245) rear tire available? Unfortunately, the next step up is a 275/60/15, which is VERY borderline in the 67s
Mickey Thompson Sportsman S/T wheels 7" front & 7" rear 225/60/15 and 255/60/15 ($880 for the four) 225 = small front tire - too short!! With the Sportsman S/Ts, I can also source 225/70/15s and 235/60/15s.
#885806
12/22/10 11:57 PM
12/22/10 11:57 PM
StealthWedge67
Puyallup, WA
stance with worn out leaf springs.
#885809
12/23/10 12:36 AM
12/23/10 12:36 AM
Damned67
Tomorrow.
Thanks for that Gary (and for all the pics). So the trade off would be whether to run with the 15x7 @ 4" BS or the 15x8 with the 4.5" BS. Either way, a 255 tire should fit (at least, it looks like it will).
[Re: Damned67]
#885810
12/23/10 12:43 AM
12/23/10 12:43 AM
6bblgt
Las Vegas, NV
If everyone is measuring backspace the same - the bigger 255 tire on a 8" wheel would be 3/4"+ closer to the wheel lip.
I don't think there's room for that.
[Re: 6bblgt]
#885811
12/23/10 02:50 AM
12/23/10 02:50 AM
Damned67
Tomorrow.
Got me thinking now.... The section width on the tire in the photo (Dunlop GT Qualifier, 245/60/15) is reported to be 9.6" on a 7" rim. The Sportsman 255/60/15 is reported to be 10.25" on a 7.5" rim. Accounting for the difference in the backspacing, the Sportsman on a 7.5 rim would, indeed, sit ~0.6" closer to the lip. How much would an 8" rim change the section width?
