NEED HELP PICKING A CLUTCH FORK!!!!!!!!!!!!!!! #88534
07/14/08 03:47 PM
07/14/08 03:47 PM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
I just put a 4 speed O/D in my 1973 Roadrunner and I'm having problems getting the right clutch fork. I one I was using before is a short fork and when I put it in the O/D bellhousing, it doesn't quite reach the throw out bearing. So then I put one of my longer forks in and the end that clutch rod pushes on is now to long, but it fits the T/O bearing perfect.
What is the answer?
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: NEED HELP PICKING A CLUTCH FORK!!!!!!!!!!!!!!! [Re: mopar_leaner] #88535
07/14/08 05:03 PM
07/14/08 05:03 PM
USA
rftroy Offline
rftroy  Offline
USA
Because of the large diameter bearing retainer used on the O.D. 4, the shift fork pivot had to be moved out away from the transmission centerline. This makes the fork longer from the pivot to the end of fork which contacts the throwout bearing retainer. The fork was made longer to lower the force required to actuate the clutch.
You need to get a fork from an O.D. 4 transmission application. Sounds like you may have one and it's thrown the geometry off. You may need to modify the torque shaft.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: NEED HELP PICKING A CLUTCH FORK!!!!!!!!!!!!!!! [Re: rftroy] #88536
07/14/08 06:50 PM
07/14/08 06:50 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
there were no overdrive 4 spd B-bodies made so you need to modify the torqueshaft/z-bar/bellcrank to work with the long fork
Re: NEED HELP PICKING A CLUTCH FORK!!!!!!!!!!!!!!! [Re: 446acuda] #88537
07/14/08 09:48 PM
07/14/08 09:48 PM
Hermiston Oregon
Hermiston Oregon
I just had my machinist torch the long fork, which cleared the front bearing retainer, and shorten it to the same length as the fork that came out of the car to start with. It works perfect!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
