67 GTX or R/t #88422
07/14/08 11:33 AM
07/14/08 11:33 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
I know that all 440 motors that had A/c came with the cooling package including 26 inch radiator. Did the 67 R/T or GTX come with a 22 inch rad if they didn't have the cooling package or A/C ??(440 motor)
Re: 67 GTX or R/t [Re: terzmo] #88423
07/14/08 12:14 PM
07/14/08 12:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No, they all had 26 inch radiators, just different numbers for 440's or Hemi's.
Re: 67 GTX or R/t [Re: ScottSmith_Harms] #88424
07/14/08 06:07 PM
07/14/08 06:07 PM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
Not sure if that is correct Scott. My 69 X came with an 053 (22") from the factory (non-A/C, air grabber convert.) It is on the build sheet as such.
Re: 67 GTX or R/t [Re: TrueTripleX] #88425
07/14/08 06:15 PM
07/14/08 06:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
We are talking 1967 only, trust me, it's correct.
To make matters clearer the only two choices ended in either 934 or 936. Hemi's and 440 A/C cars got the 3 row 934, all other 440's got the 2 row core 936.
Re: 67 GTX or R/t [Re: ScottSmith_Harms] #88426
07/14/08 06:35 PM
07/14/08 06:35 PM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
I bow to the master Scott. These old eyes didn't see the 67 in the "fine print". You are correct that they were all 26".
