Re: Max Wedge exhaust manifolds on a '62 361?
[Re: mopower76]
#884212
12/20/10 06:12 PM
12/20/10 06:12 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Because the 361 heads are lower/narrower than the original 413 the crossover pipe might not fit right.
[Re: John_Kunkel]
#884213
12/20/10 06:50 PM
12/20/10 06:50 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
413's are the red headed stepchildren of the RB family. If you are going to foot the expense of the full MW exhaust system, you can pick up a running 413 for less than you will have in the MW exhaust system and then have a entire upgraded engine for your time and trouble and the exhaust should fit without question.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: topside]
#884217
12/20/10 09:35 PM
12/20/10 09:35 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I have a Maxie exhaust system on my '63 (446" RB, 4-speed) wagon, and I can tell you spark plug access on the right side is a pain in the butt. Looks killer, though. You also need to shield the master cylinder if you go to the later 2-circuit type, and the heater hoses need to be routed further away. There is some wiggle room on the crossover. The e-brake cables also required re-routing, but I used a later rearend with the later cable arrangement.
Come on Steve,you know it's easy.
[Re: mopower76]
#884219
12/20/10 10:17 PM
12/20/10 10:17 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Am I to assume the MW manifolds will interfear with the Booster even though it is a more narrow 361?
I've never tried it with a low deck but it's a pretty safe assumption that you'll run into problems.
[Re: mopower76]
#884221
12/20/10 10:40 PM
12/20/10 10:40 PM
Posts: 426 Randolph, Ohio--N.E. Ohio
Goat330
There shouldn't be any problem putting MW exhaust on a low deck motor. My oldest brother bought a brand new 64 Fury w/383 and one of the 1st things he did was put a complete MW exhaust on the car. I still remember he would un- cap the cut-outs when street racing, and you could hear the car being shut -off & coasting down the street in the middle of the night, trying to sneak in so our dad wouldn't hear him.
[Re: mopower76]
#884223
12/20/10 11:25 PM
12/20/10 11:25 PM
62maxwgn
Blair County,PA
Well I guess I have my answers on the exhaust. I'm not trying to go fast, just a good sounding and running cruiser. The car is a factory 361 4BBL as stated prior, with p/s, A/C, and p/b. Cool car that has been in storage since 1970. I thought as I was going to be replacing ALOT I may as well unbolt and upgrade while keeping the #'s correct.
With a few changes,you can still run your A/C.Here is my 62.You may be able to get away with an A body Midland-Ross booster.They are about 8" in diameter but wouldn't bet on it.
[Re: mopower76]
#884229
12/21/10 03:26 PM
12/21/10 03:26 PM
Posts: 4,799 ILL
MLR426
ILL
Thanks for the info guys! I have been talking with a buddy that owns an exhaust shop across town that thought it was crazy to spend that much and he can do a 3"w/cutouts and turndowns for way less so I think I will go that route with the MW Manifolds. The car does have Power brakes. . . Am I to assume the MW manifolds will interfear with the Booster even though it is a more narrow 361?
Hope I dont have to scrap the whole Idea, I love the MW look but not a necessity.
Would there be any benifit to bolting on the rebuilt set of '76 440 heads I have. (if only for the hardened valve seats)
That's a face only a mother could love.
logan426
[Re: Goat330]
#884232
12/22/10 01:16 AM
12/22/10 01:16 AM
Posts: 422 wisconsin united states
keith airgrabber
Right in the Nutz!!!
That sounds awesome. I am building a 1964 polara with a 440 and I am going to use the max wedge system. How cool is the sound uncorked? I can't wait to hear it.
[Re: RapidRobert]
#884233
12/22/10 07:51 AM
12/22/10 07:51 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Any thoughts on the 76 head swap?
With the '76 heads, eventhough flow might be better, you still throw away a half point of compression ratio, piston-quench is def. out the window aswell, and if the heads were rebuild and had a valve job, the grinder most likely ground through the hardened area of the seats, leaving you with unhardened seats again.
I would stick with the stock heads and it's 4-bolt valvecovers, or better spend the money on a much more torqier 413 orso.
