Re: Max Wedge exhaust manifolds on a '62 361?
[Re: Goat330]
#884232
12/22/10 01:16 AM
12/22/10 01:16 AM
Posts: 422 wisconsin united states
keith airgrabber
Right in the Nutz!!!
That sounds awesome. I am building a 1964 polara with a 440 and I am going to use the max wedge system. How cool is the sound uncorked? I can't wait to hear it.
[Re: RapidRobert]
#884233
12/22/10 07:51 AM
12/22/10 07:51 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Any thoughts on the 76 head swap?
With the '76 heads, eventhough flow might be better, you still throw away a half point of compression ratio, piston-quench is def. out the window aswell, and if the heads were rebuild and had a valve job, the grinder most likely ground through the hardened area of the seats, leaving you with unhardened seats again.
I would stick with the stock heads and it's 4-bolt valvecovers, or better spend the money on a much more torqier 413 orso.
