Smokey 360 #88317
07/14/08 09:20 AM
07/14/08 09:20 AM
SE, Pa
Hotwheel Offline OP
Hotwheel  Offline OP
SE, Pa
Would like some opinions on my E58 360 in my 79 300. It would give me a big cloud of smoke out of the exhaust after it sat for awhile. So I replaced the valve seals and now it doesn't smoke after sitting a while, but it smokes out of the drivers side exhaust when you shut it off and restart it a few minutes later. It continues to smoke for a few minutes and when you drive it you can see just a faint hint of smoke out the drivers side pipe. Also running at highway speed around 3000 RPM and you let off the throttle to get off at an exit it smokes. I got a idea what I need to do, but would like a few opinions please.
09 Challenger B5 Classic 78 Magnum GT Check out my Website http://home.comcast.net/~tlyerk/troy1.html
Re: Smokey 360 [Re: Hotwheel] #88318
07/14/08 09:48 AM
07/14/08 09:48 AM
twin cities
dart_sportsatellite Offline
twin cities
What color smoke? Since you replaced valve seals I'm thinking blue?
Re: Smokey 360 [Re: dart_sportsatellite] #88319
07/14/08 10:05 AM
07/14/08 10:05 AM
scratchnfotraction Offline
I bet on valve guids worn and new seals cant stop the oil...but sounds it slowed it down and to one side
Re: Smokey 360 [Re: dart_sportsatellite] #88320
07/14/08 10:18 AM
07/14/08 10:18 AM
SE, Pa
Hotwheel Offline OP
Hotwheel  Offline OP
SE, Pa
Yeah, blueish white smoke. The engine has about 75K on it, runs good, no distinctive miss. When I replaced to seals they where hard, but not crumbling apart like some I have done. I did them last week and drove the car to Carlisle Friday and Saturday, putting about 500 miles on it. It used about a Quart of oil in that amount of time.
Re: Smokey 360 [Re: dart_sportsatellite] #88321
07/14/08 01:25 PM
07/14/08 01:25 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
Check for an intake leak. My Duster had the same issue, slight smoking and oil consumption numbers.There was only a quarter inch long crack in the passenger side gasket, near the bottom, just enough to pull oil. I put a new set on and no more smoke, still full of oil after 700 miles and running great. Just a thought.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Smokey 360 [Re: MoparJ] #88322
07/14/08 01:42 PM
07/14/08 01:42 PM
P
Paul_Fancsali Offline
P
Just did the intake gasket on my E58 the smoke problem is history
Re: Smokey 360 [Re: Paul_Fancsali] #88323
07/14/08 04:37 PM
07/14/08 04:37 PM
SE, Pa
Hotwheel Offline OP
Hotwheel  Offline OP
SE, Pa
Was the gasket that bad that it sucked oil from inside the engine into the intake?
Re: Smokey 360 [Re: Hotwheel] #88324
07/14/08 05:26 PM
07/14/08 05:26 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
I can't speak for what happened on this E58, but that is more or less what happened to mine. It had a small crack on the right side gasket on the bottom. Presumably, when letting off the gas, it was pulling the oil through the crack and burning it through the exhaust and combustion chamber, thus causing the blue smoke and oil consumption. The vacuum was pulling oil out of the valley; there was slight discoloration in the corresponding intake runner.
Re: Smokey 360 [Re: MoparJ] #88325
07/14/08 10:53 PM
07/14/08 10:53 PM
SE, Pa
Hotwheel Offline OP
Hotwheel  Offline OP
SE, Pa
Well at this point a set of intake gaskets is a cheap investment before I pop the heads off. Thanks for the suggestions Guys
Re: Smokey 360 [Re: Hotwheel] #88326
07/15/08 10:16 AM
07/15/08 10:16 AM
twin cities
twin cities
I've heard that sometimes you can try retightening the intake and that'll take care of it. That's my first step, but it's a new engine, and the intake was just a skosh loose after about 100 miles. Hoping it works.
