90 dodge daytona check guages light #88224
07/13/08 09:27 PM
07/13/08 09:27 PM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
what causes check guages light to come on? can i buy a scan tool for working on this car? Brad
Re: 90 dodge daytona check guages light [Re: roadrunnerreds] #88225
07/13/08 11:06 PM
07/13/08 11:06 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Are all the gauges reading properly?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 90 dodge daytona check guages light [Re: roadrunnerreds] #88226
07/14/08 10:59 PM
07/14/08 10:59 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Did you try checking for codes?
this can be done by cycling the key 3 times.
Key on - Key off - Key on - Key off - Key on (let key in the on position)
Watch the "check engine" light, as it will start to flash
You should get something like this:
flash-[short pause]-flash-flash (that's a code 12)
Then a [long pause]
flash-flash-flash-flash-[short pause]-flash-flash-flash-flash (that's a code 55)
and so on.
Check and report back with the codes and we'll go from there.
Oh...and only cycle the key to the "on" position, not the "start" position each time!!!
