Re: T/A wiring problem
[Re: Sixpackman340]
#88137
07/13/08 10:42 PM
07/13/08 10:42 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I have had this happen on several Mopars. The bulkhead connectors carry a lot of current from under the hood. The corrosion from water leaking into it creates an ohmic connection causing it to heat. The current increases until the fusible link melts. To fix it, disconnect the ground terminal from the battery. Take apart the bulkhead connector and see if the contacts can be cleaned or if they have to be replaced. Replacing them can be tricky. I had a 72 Satellite where I had to rewire around the connector using spade lugs. The connector had melted and I passed the wires through the hole it made. Did not look pretty but worked. It was my driver so I was not too upset about it. Getting a new connector is just about impossible. I keep my Cudas clean inspecting it at every oil change. I spray it with contact cleaner made for TV tuners that you can get at Radio Shack. You replace the fusible link with butt splice on one end, if you can get the Mopar link, it comes with the ring lug on the other end. Fusible links are usually a lighter gauged slightly resistive wire that is designed to be the weak point in the system. They were used because fuse technology had not brought about high amperage easily replaced fuses. Any other questions, just ask. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Sixpackman340]
#88139
07/16/08 05:15 PM
07/16/08 05:15 PM
denfireguy
Colorado
That is puzzling. As my fuzzy memory serves me, the link went straight to the connector unless it was changed out. Lots of them went out so I am sure the odds that it had never been repaired previously is pretty high. Add on accesories like stereos, CBs and dealer air conditioning added to the current load. Todays electronic equipment draws a lot less (with the exception of the heavy duty thump thump audio amps) off the wiring. I was in amateur radio, so I stressed a lot of them out but the corrosion did me in more than what I sucked out of the system. Craig
2003 Durango, 74 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan
