Page 1 of 4 1 2 3 4
straight vs. split pattern cams #880733
12/15/10 01:04 PM
12/15/10 01:04 PM
Essex, Ont., Canada
Fishmarket Offline OP
Essex, Ont., Canada
Can someone explain when and why it would be advantaageous to use a split pattern cam with more exhaust duration, and when a greater exhaust duration would start to be detremental?
I can see using a split on an engine breathing through exhaust manifolds but what if your heads are ported and you have a free flowing header/exhaust set up? Can too much exhaust duration hurt power output?
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: straight vs. split pattern cams [Re: Fishmarket] #880734
12/15/10 01:36 PM
12/15/10 01:36 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Testing has show for a given intake profile they will give a little more power with a longer exhaust duration.
so lets say a standard 236/236 @ .050 110 LSA cam changing it to a 236/244 @ .050 cam will give a little more power and not effect the drive ability from where it is.
the norm seems to be 6 to 10 more on the exhaust to get rid of that expanded hot exhaust charge.
Re: straight vs. split pattern cams [Re: Dodgem] #880735
12/15/10 02:11 PM
12/15/10 02:11 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
The magic number, here, is 75%. You want your exhaust port to flow @ 75% of your intake port. Most stock heads (especially BB mopars) don't do this, so cam manufacturers figured they can compensate for the heads shortcomings by extending the duration on the exhaust side.
What has happened now, is that split pattern cams have just become the norm, and the general public percieves they are getting a better engineered product with varying #'s on the card (not really knowing why)
Most good aftermarket heads do support the 75% number, however.
The key when choosing a cam is knowing what your heads will flow, and complimenting that curve with the cam. With good heads that flow properly, there is a strong case to be made that you'll maximize the power available from a given duration and lift spec. with a square pattern cam. Your intake, carburetor, and header selection also plays a role here.
I conferred with Member, Jeff Patterson, when choosing my cam, and we both agreed that my combo seemed to call for a square pattern cam, so that's what we dialed up from Engle.
Re: straight vs. split pattern cams [Re: StealthWedge67] #880736
12/15/10 02:17 PM
12/15/10 02:17 PM
organ
maximum entropy Offline
organ
WHAT HE SAID.
Re: straight vs. split pattern cams [Re: Dodgem] #880737
12/15/10 02:32 PM
12/15/10 02:32 PM
UK
602heavy Offline
602heavy  Offline
UK
Opinions are just that , here's mine FWIW.
Running too much exhaust duration with low compression engines just kills torque , exhaust valve requires a later opening to take advantage of later peak pressure associated with low compression ratios , opening exhaust valve to early won't give the expanding gasses enough time/leverage to push on piston , using a faster lobe can help regards pumping lossess , sometimes a higher ratio rocker arm on exhaust can help when going shorter on exhaust duration................the other problem with long duration exhaust lobes is the overlap period , once the piston moves away from TDC on intake stroke it's drawing on both intake & exhaust port , any spent gasses left in the exhaust port will be sucked into the cylinder along with fuel'air from intake port , the longer the exhaust valve is held open on intake stroke the more contaminated the charge will be , this is the reason tighter lobe centres produce less vaccume & run pretty rough @ idle , the cleaner the intake charge the more power the engine will produce.
Using restricted exhaust manifolds along with later closing exhaust valves (longer overlap period) makes matters worse on street engines that only spin to around 3500/4000 rpm , unless that exhaust can scavenge intake charge will be contaminated.......why is it advancing intake centreline makes more torque low down? , LESS CONTAMINATION......all you guys using split patterns (low comp) go loosen lash on exhaust valve & notice the motor pick up , will idle a bunch nicer too.
Just my , feel free to bash the hell out of it.
Re: straight vs. split pattern cams [Re: Fishmarket] #880738
12/15/10 03:17 PM
12/15/10 03:17 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Whose testing? I've seen some that show that the proper single-pattern cam will provide more power through the entire range. So, who do you believe?
Sorry, there is NO MAGIC NUMBER. That "75%" rule is outdated.
Opinions are just that...
I won't argue that point.
Re: straight vs. split pattern cams [Re: BradH] #880739
12/15/10 03:22 PM
12/15/10 03:22 PM
UK
602heavy Offline
602heavy  Offline
UK
Hey Budget , what does 'do not feed the troll' mean?
Re: straight vs. split pattern cams [Re: Fishmarket] #880740
12/15/10 03:29 PM
12/15/10 03:29 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
If you were to ask 5 different camshaft manufaturers this question,you would get 5 different answers.
It would depend on what the engine is intended to be used for,cylinder head flow,compression ratio,etc.
As far as the 75% rule,I agree that is outdated,but something people tend to use anyway.
Re: straight vs. split pattern cams [Re: 602heavy] #880741
12/15/10 04:12 PM
12/15/10 04:12 PM
BradH Offline
BradH  Offline
It means I'm in kind of a crappy mood and this is just the sort of thread that could cause me to post of bunch of smart@ss comments in my replies.
Re: straight vs. split pattern cams [Re: Fishmarket] #880742
12/15/10 04:16 PM
12/15/10 04:16 PM
AndyF Offline
AndyF  Offline
I spent a bunch of money dyno testing camshafts on my 470 low deck motor. It had exhaust manifolds and lots of people told me that I would need extra duration on the exhaust side to compensate for the manifolds. Turns out that the very best camshaft for that engine was the old school Mopar .528 solid flat tappet.
I suppose if I was given unlimted funds I could find a camshaft that was even better than the .528. And perhaps, after hunreds of dyno pulls the very best cam might well be a split pattern cam. But I called it quits after spending a couple of grand on cams and dyno time.
As far as I know, nobody knows the answer to this question. It is fairly easy to get a 90% correct answer to the question, but I don't think anyone has ever really figured it all out. If they had, then there wouldn't be any need for all of the dyno testing that goes on every day at all of the engine shops around the world.
Re: straight vs. split pattern cams [Re: AndyF] #880743
12/15/10 04:32 PM
12/15/10 04:32 PM
UK
602heavy Offline
602heavy  Offline
UK
Right then , take it the jurys out for single pattern grinds.
Used 14 degree split when on the bottle , but that's a different story.
Re: straight vs. split pattern cams [Re: BradH] #880744
12/15/10 04:35 PM
12/15/10 04:35 PM
UK
602heavy Offline
602heavy  Offline
UK
It means I'm in kind of a crappy mood and this is just the sort of thread that could cause me to post of bunch of [Email]smart@ss[/Email] comments in my replies.
I wanna know who's the TROLL.
Re: straight vs. split pattern cams [Re: 602heavy] #880745
12/15/10 05:13 PM
12/15/10 05:13 PM
BradH Offline
BradH  Offline
That refers to ME. Although I tell my kids my parenting role model is Shrek and he's an ogre, not a troll.
Re: straight vs. split pattern cams [Re: 602heavy] #880746
12/15/10 05:29 PM
12/15/10 05:29 PM
AndyF Offline
AndyF  Offline
Single pattern cams seem to work just fine in a lot of engines including most OEM engines.
I just finished up some camshaft testing in one of my big block motors where I was using a Comp MM 293 single pattern cam. It made 660 hp which is a decent number for an inexpensive flat tappet cam. This is with Edelbrock RPM heads which aren't noted for having a fantastic exhaust port. Maybe a dual pattern cam would make more power, maybe it wouldn't. Point is that 660 hp is enough power to put most Mopar race cars into the 9's. So for a typical bracket racer, why mess around with a bunch of cam theory when a simple cam off the shelf will run plenty hard.
440Jim runs a MM 305 (single pattern, flat tappet) shelf cam and he is knocking on the 8 second door.
Re: straight vs. split pattern cams *DELETED* [Re: Fishmarket] #880747
12/15/10 09:39 PM
12/15/10 09:39 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Post deleted by polyspheric
Boffin Emeritus
Re: straight vs. split pattern cams [Re: BradH] #880748
12/15/10 11:46 PM
12/15/10 11:46 PM
Puyallup, WA
Puyallup, WA
Well, if opinions are "just that", then I'll consider yours to be the low side of the analogy. You've certainly provided plenty of facts to support your rant, there..... (oh, maybe not) Until you can show me actual numbers that say the 75% rule is untrue, I'm going to consider your opinion completely arbitrary. Perhaps I should have called it a "rule of thumb", not a "magic number", this I'll concede. But the facts remain. This number is based on the physics of volumetric transfer. I don't think these mathematical equations "expire" with time. Why does just about every internal combustion head ever manufactured feature an exhaust valve approx. 75% of the intake? You may really mean to point out that this rule of thumb isn't foolproof every time??. To which I'd still ask you to come up with a fact based equation that outweighs it. Bottom line, heated exhaust gas needs approx. 75% of the volumetric space to travel at the same velocity as the cooler, wetted intake charge. If a heads flow capability doesn't support that mathematical certainty, then adjusting the exhaust valve duration to compensate has become the accepted path that cam manufacturers have followed.
Re: straight vs. split pattern cams [Re: polyspheric] #880749
12/15/10 11:47 PM
12/15/10 11:47 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thats exactly what I was going to say, you beat me to it. mike
Re: straight vs. split pattern cams [Re: Sport440] #880750
12/15/10 11:59 PM
12/15/10 11:59 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
what do the FAST class guys run?
Re: straight vs. split pattern cams [Re: sixpackgut] #880751
12/16/10 12:08 AM
12/16/10 12:08 AM
Puyallup, WA
Puyallup, WA
According to the writeup on Joel Nystrom's 67 GTX in MuscleCar Review last month, He reportedly runs heads that have been custom ported to flow 420 on the intake, and 315 on the exhaust.... (at this point I would ask you to do the math on that relationship).
The same writeup notes that he employs a camshaft that features 4% more duration on the exhaust side. This makes sense, since his hemi runs 1250 cfm worth of dual AFB on the intake side, but stock exhaust manifolds on the exhaust side.
Re: straight vs. split pattern cams [Re: StealthWedge67] #880752
12/16/10 12:20 AM
12/16/10 12:20 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
420/315 what does a head done for super stock flow?
Page 1 of 4 1 2 3 4
