70 R.R. rear window clip holes,need some location help #87916
07/13/08 09:44 AM
07/13/08 09:44 AM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
hello,need to know some rear window clip holes,basicly a measurement from the bottom center to the outer ends,and from the first hole in the sides down. thank you for any help that you guys can provide please. Darren
Re: 70 R.R. rear window clip holes,need some location help [Re: meepmeep70] #87917
07/13/08 02:48 PM
07/13/08 02:48 PM
weymouth,mass.
weymouth,mass.
NE1 please?
Re: 70 R.R. rear window clip holes,need some location help [Re: meepmeep70] #87918
07/13/08 08:27 PM
07/13/08 08:27 PM
weymouth,mass.
weymouth,mass.
maybe the night shift can help
Re: 70 R.R. rear window clip holes,need some location help [Re: meepmeep70] #87919
07/13/08 09:21 PM
07/13/08 09:21 PM
Central, NY
DanMcG Offline
DanMcG  Offline
Central, NY
I'm not following what you're asking?
is this post any help;
https://board.moparts.org/ubbthreads/show...rue#Post4546126
Re: 70 R.R. rear window clip holes,need some location help [Re: DanMcG] #87920
07/13/08 09:49 PM
07/13/08 09:49 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
All of this begs the question (mine is comming up)
Does the spacing really matter in terms of being so accurate as long as you have enough clips?
Not something that would ever be seen for a concours correct type of judgement.
Driving modern convenience in classic beauty
Re: 70 R.R. rear window clip holes,need some location help [Re: Darius] #87921
07/14/08 08:11 PM
07/14/08 08:11 PM
weymouth,mass.
weymouth,mass.
thanks Dan, in regards to concours,i'm not into that type of restoration,just wanted to have the clips in about the right location so as to only do this once. Dan pics plus measurements was just what i needed thank you. Darren
