Fixing junk Chinese Body parts ? #87886
07/13/08 02:20 AM
07/13/08 02:20 AM
Gateway to the West.
hemi_harvester Offline OP
I bought a cheap (junk) new Chinese valance panel it has mounding brackets SPOT welded to it. The spot welds left dents what is the best way to fix it besides throwing it away? I was going to use the GREEN spot putty but I have heard it should be ground down and the reprimered first? Wouldn't you want to bondo the bare metal then primer it?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Fixing junk Chinese Body parts ? [Re: hemi_harvester] #87887
07/13/08 02:49 AM
07/13/08 02:49 AM
Maryland
reno340 Offline
reno340  Offline
Maryland
I would give it a little grind in the spotweld area and then would spread a litle fiberglass and sand that down. The fiberglass will take care of any pinholes that might be present.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: Fixing junk Chinese Body parts ? [Re: reno340] #87888
07/13/08 06:40 AM
07/13/08 06:40 AM
places
79powerwagon Offline
places
You're referring to the glass paste, right? That's what we used over the welds. Even though bondo and glass are both polyester based products, the bondo uses clay and other types of powders to make the paste, which can absorb moisture. The glass paste won't.
All replacement sheet metal takes a bit of massaging, so to expect anything more, regardless of the source, is futile.
