70 Challenger 340 PS Hose Pictures
#878123
12/12/10 12:30 PM
12/12/10 12:30 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
I need to replace the power steering hose on my car and I bought one from NAPA and it does not seem to be the correct one, or I should say that the one that I bought does not match the one that is on the car. Could someone post pictures of what each end should look like so I can determine which hose that I have is correct? The hose that I am referring to is the one with fittings on both ends. I believe that I have the Saginaw type pump and both of my current hoses (NAPA new and existing) measure around 28" long. I have looked up the hose on YO and they show that they should be 35" long so I am confused which one I should have for the car. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: 70 Challenger 340 PS Hose Pictures
[Re: 6bblgt]
#878125
12/12/10 06:17 PM
12/12/10 06:17 PM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
A '70 340 car should have a Federal power steering pump. ('69 model year used Saginaw)
Dan, My 1970 challenger 340 also had a saginaw pump the date code on the pulley was in line with the cars SBD
[Re: gtx6970]
#878126
12/12/10 09:25 PM
12/12/10 09:25 PM
YO7_A66
Indiana
I took a couple of pictures of what the existing pump/hose ends look like. Maybe this will help determine which pump I have and which hose I need.
#1 Thanks
[Re: YO7_A66]
#878128
12/12/10 10:05 PM
12/12/10 10:05 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
Did you buy that current hose at one time? Usually that style hose comes out of the steering box pointed forward. Wonder if someone bent it up.
The 71 340 or 383 sagninaw E-body hose should work with that.
BTW that pump has a later square resivour 74? up style. Check if you current pump pressure inlet is a 3/8" Male Inverted Flare. That's a replacement pump you have that might not have the 70 fitting size (sort of looks like the right one in you pic though).
Gates p/n 352840 Pressure Line Assembly; 5/16" Female SAE x 3/8" Male Inverted Flare x 34 1/4" W/Saginaw P.S. Pump for 71 E-body with 340 and saginaw pump.
http://www.rockauto.com/catalog/moreinfo.php?pk=78307
[image]http://info.rockauto.com/getimage/getimage.php?imagekey=78307&imageurl=http%3A//www.gatespowerpro.com/resources/images/352840.jpg[/image]
[Re: autoxcuda]
#878129
12/12/10 11:59 PM
12/12/10 11:59 PM
YO7_A66
Indiana
P/S Hose End Type : 5/16" Female S.A.E. x 3/8" Male Inv. Flare Power Steering Hose Imperial Length : 34 1/4" I found your description to match another one at NAPA that I can pickup. http://www.napaonline.com/Search/Detail.aspx?A=NPS7610_0135925189&An=599001+101970+50020+2020006 That is a replacement pump and the hose was on the car when I bought it 9+ years ago. I will trade in my current new hose for the hose with the above description. Thank you
[Re: autoxcuda]
#878131
12/13/10 08:59 AM
12/13/10 08:59 AM
YO7_A66
Indiana
So the NAPA 71574 worked fine for your 340/Saganaw even though the description shows it for a 383/440? Does it matter if i need a 3/8 inverted flare versus a 3/8 o-ring type? I agree, my current hose does not look like the correct application. Does the 71574 go behind, or underneath the ps pump?
Thank you very much.
[Re: YO7_A66]
#878132
12/13/10 01:05 PM
12/13/10 01:05 PM
autoxcuda
So Cal
Yes, absolutely critical. You have inverted flare right?
It goes behind and to the side fo the p/s pump.
Here's a pic of one in my Dart.
[Re: autoxcuda]
#878133
12/13/10 01:20 PM
12/13/10 01:20 PM
YO7_A66
Indiana
I am not sure if I have the flare or the o-ring, I have not had that hose off yet. I was waiting to remove it once I had a hose that looked correct first. I will be picking up a NAPA 71574 tonight. It has the o-ring but I will try it and see. Thanks for the picture.
[Re: autoxcuda]
#878134
01/09/11 09:29 PM
01/09/11 09:29 PM
YO7_A66
Indiana
Auto, I finally got around to testing the 1574 hose from NAPA. What I found is that the NAPA hose has a female fitting for the power steering box (right end of the below picture), and my power steering box has a female thread (ref the #1 picture at the top of this thread). So I would need a male/male fitting to make this hose connect. Does this sound right? The fitting at the power steering pump end looks fine but the bend is wrong. I could rebend the metal tube to make it work though. If I can find a fitting to adapt this hose, I will bend it to fit. I wonder if I have a replacement power steering box that is messing this up along with the replacement pump combo too.
Update: I just checked a 74 Challenger 360 ps hose and it does have the 5/16 male o-ring fitting for the ps box. I must have a 74 box then. I could not find the correct adapter so I have ordered the NAPA #7-6115 hose that has the correct ends but the bend in the tube will need to be modified. Thanks
