64 belvedere 4 speed bell housing #87713
07/12/08 08:52 PM
07/12/08 08:52 PM
south carolina
gastongremlin Offline OP
south carolina
can someone tell me the part number for the correct big block bell housing for a 1964 belvedere. it is a 10 1/2 clutch. i have most of the original parts except the bell housing which disappeared over the years.
thanks, john
Re: 64 belvedere 4 speed bell housing [Re: gastongremlin] #87714
07/16/08 01:49 AM
07/16/08 01:49 AM
south carolina
south carolina
any ideas at all?
Re: 64 belvedere 4 speed bell housing [Re: gastongremlin] #87715
07/16/08 08:02 AM
07/16/08 08:02 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Actually it should be an 11" housing.Casting # 2463019.Same for 361/383/426.
Re: 64 belvedere 4 speed bell housing [Re: 62maxwgn] #87716
07/16/08 05:07 PM
07/16/08 05:07 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
The casting number above is correct, but it is a 10.5" bellhousing. This was a one year only bell. I should have one.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
