70 Challenger 440-6pk Questions
#87444
07/12/08 10:56 AM
07/12/08 10:56 AM
I am finishing up the engine bay on my Challenger, and have a few questions.
1. Would this have come with a torque strap and if so, where can I find one?
2. Does the Mopar Performance fan clutch look like the original? I bought one from O'Reilys, but am told the "slots" in lieu of mounting holes are not correct.
3. Where can I get the correct air filter with the correct "screening" over the filter element?
4. What is proper length for the engine ground strap and who has it?
5. I need the correct power steering hose(pressure side) and also the power brake booster vacuum hose. Where can I find these?
Thanks for any and all input.
Re: 70 Challenger 440-6pk Questions
#87445
07/12/08 11:48 AM
07/12/08 11:48 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
1. Would this have come with a torque strap and if so, where can I find one? No torque strap was used on that car.
2. Does the Mopar Performance fan clutch look like the original? I bought one from O'Reilys, but am told the "slots" in lieu of mounting holes are not correct. The P4120758 fan pakage has a clutch that looks close and does have the four holes instead of the slots. I have this kit in stock for around $100.00.
3. Where can I get the correct air filter with the correct "screening" over the filter element? Those filter are still around. Give Bill a call at A&M High Tech. (859) 689-7893
4. What is proper length for the engine ground strap and who has it? See above...
5. I need the correct power steering hose(pressure side) and also the power brake booster vacuum hose. Where can I find these? See Bill again....
Hope this helps..
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#87447
07/12/08 06:02 PM
07/12/08 06:02 PM
Troy,
Thanks for the input. Can you please send me a picture of the fan clutch you have, front and back?
I will contact Bill and also John Grinwald who I understand also can make up date coded hoses.
Thanks, David
