How to tell the difference in A-body K-frames? #87216
07/11/08 10:42 AM
07/11/08 10:42 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I have two A-body K-frames that I think are V-8 frames but I'm not positive. One is the 67-72 biscuit mount type and the other is a 73-up spool mount type. How do you tell the difference between V-8 and slant six K-frames for both applications?
Re: How to tell the difference in A-body K-frames? [Re: 6PAX] #87217
07/11/08 11:46 AM
07/11/08 11:46 AM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
Go to www.engine-swaps.com and chose the "K-member Identification Guide". You'll have your answer.
TRH
You can lead a gift horse to water, but you
can't look in his mouth.
Re: How to tell the difference in A-body K-frames? [Re: ChickMaggot] #87218
07/11/08 01:46 PM
07/11/08 01:46 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
73+
Look at the drivers side mount area and compare the height to the pass side. If it's taller, /6. Same height, v8.
Re: How to tell the difference in A-body K-frames? [Re: 6PAX] #87219
07/11/08 02:17 PM
07/11/08 02:17 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Here you go. Because of the screen in the image you'll need to download and view the picture on your computer. The picture will then appear very clear.
