LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? #871174
12/04/10 03:41 PM
12/04/10 03:41 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I plan on testing out a few borrowed carbs on my GTX..between now and this spring. Can anyone steer me in the right direction on what electronic equipment I should be purchasing to set up the carb systems correctly? The exhaust system has a bung installed on the header collector,which was done for chassis dyno-testing,last spring. Thanks in advance for your opinions! Randy B.
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Labratt] #871175
12/04/10 03:45 PM
12/04/10 03:45 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
did you want data record or just gauge readout?
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Labratt] #871176
12/04/10 04:10 PM
12/04/10 04:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy you can use my LM-1 if you want... since you
have a bung in already it would be easy... mine doesnt
record to the unit but if you can see it you can
get the number OR have someone read it
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Labratt] #871177
12/04/10 05:05 PM
12/04/10 05:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I like my LC-1 and it comes w/a disc so "smart people " can download the program so u can run a lap top and store and play back your runs later.
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Thumperdart] #871178
12/04/10 05:49 PM
12/04/10 05:49 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks guys! Mike,that would be great! Maybe I can get it when I bring my 6 "little buddies" over for a visit shortly! My biggest concern is the A/F ratio at idle! I'd like to see what settings would give it the leanest(cleanest)exhaust emission...and still be "safe" BTW...what is considered the "IDEAL" A/F ratio(on the idle circuit) on a car like mine? 13-13.5-1? THANKS!
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Labratt] #871179
12/04/10 05:52 PM
12/04/10 05:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In the 14s... thats a no load condition... just
enough fuel to give a nice clean idle... but then
again you have one of them there bumpy 3/4 race cams
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: MR_P_BODY] #871180
12/04/10 06:09 PM
12/04/10 06:09 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Mike! I want the plugs to look like the one on the right..even just idling around!..or is that a "pipe dream"? Actually, the cam's only an 11/16 street unit... Made more for docile street driving,than going fast!
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Labratt] #871181
12/04/10 06:15 PM
12/04/10 06:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok... the one on the left looks both oil and fuel soaked
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Labratt] #871182
12/04/10 06:27 PM
12/04/10 06:27 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I use the LM-2 and really like that it records to an SD card. Unless you have a stock cam, don't use the A/F reading to set idle. Just set it where it idles best. If you want to be cleaner just lean it out from there as much as you're willing to tolerate.
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: MR_P_BODY] #871183
12/04/10 07:06 PM
12/04/10 07:06 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Ok... the one on the left looks both oil and fuel soaked Mike..that's why I want it to look like the one on the right! Thanks for the info,Cory! I'm just wondering if I can get the idle cleaned up with just the IAB's...not having to change the idle feed restrictors?
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: @#$%&*!] #871184
12/04/10 08:46 PM
12/04/10 08:46 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
That's exactly 100% correct........ I don't even look at the O2 when setting idle mixuture......it can be really high or really low when it's idling best with very much camshaft......
If you can't handle the truth, you're living a lie.......
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Big Squeeze] #871185
12/04/10 09:34 PM
12/04/10 09:34 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i have tried carbs on my car that felt like monsters on the street but didnt do so hot at the track. depending on what you want out of your car, any testing not at the track or even a dyno would be a waste of time if your looking for the most HP out of your motor
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Labratt] #871186
12/04/10 10:54 PM
12/04/10 10:54 PM
I shoot for 13.8 or leaner at idle, the leaner the better Every motor and fuel is not the same as every other motor and fuel so use your meter to tune your car, don't be afraid to lean it out with the mixture screws and IAB
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Cab_Burge] #871187
12/05/10 02:13 AM
12/05/10 02:13 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,feller's! Nuther' question...when using the LM-1 or other equipment,should the ambient temperature be at a standard degree..like 72*???
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Labratt] #871188
12/05/10 02:30 AM
12/05/10 02:30 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
I like the FAST Wide-Band
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Labratt] #871189
12/05/10 09:51 AM
12/05/10 09:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No.... you would be setting the A/F for the conditions
at that time... will it change due to temp and BP...
yes.... but I usually change a jet size with every 25*
of ambient so the idle will move some also... I would
wait till at least spring(since you dont drive it in
the winter) that way you would be closer to the summer
temps and conditions
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: Labratt] #871190
12/05/10 02:16 PM
12/05/10 02:16 PM
NC
440Jim Offline
440Jim  Offline
NC
I agree with Raff, the no load idle should be able to run close to Lambda=1.0 (stoichiometric), which on gas is 14.7 A/F. However, depending on the carb circuits, you may need a touch richer for throttle transition, etc.
Although I am running E85, I have leaned it out for no-load idle, and high idle around the pits at Lambda=1.0. This is primarily to put heat in the motor, but it is clean. However, my mechanical injection is much richer with the fuel valve in the full "ON" position for racing because of the simple way the system works.
Remember, the A/F numbers are just for reference when tuning. There is no magic number(s), just typical ranges like
idle 13.0-14.7
WOT 12.0-13.0
One of the nice things about recording A/F vs RPM is you can tune the fuel curve of your carb (air bleeds, jets, emulsion, etc). For example a carb at WOT might be 12.5 at 4000 rpm, but 11.5 (or 13.5) at 7000 rpm.
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: 440Jim] #871191
12/05/10 02:54 PM
12/05/10 02:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
idle 13.0-14.7
WOT 12.0-13.0
Jim maybe you would know.... is there a add on to
upgrade my LM-1 to record the data and rpm
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: MR_P_BODY] #871192
12/05/10 03:04 PM
12/05/10 03:04 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
idle 13.0-14.7
WOT 12.0-13.0
as i understand it..YES you just need the software disc and a lap top..
i have a question:
my LM-1 has 2 sensors..what is the best location to install the bungs...
i have a 2-1 y/x pipe can i put a single bung in it or should i use both banks/bungs and sensors...?
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: LM-1....OR SIMILAR CARB TUNING EQUIPMENT??? [Re: cheapstreetdustr] #871193
12/05/10 03:19 PM
12/05/10 03:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
i have a question:
cheapst
Thanks I'll check into it... as for your sensor I
put them in about 4" to 6" past the end of the
primaries in the collectors... I only have 1 sensor
but 2 bungs and after I use the sensor on each bank
I pull it out and plug the bungs... you dont want it down
stream of any e-vacs or near any open air
