Source for pitman arm boots- fixed it! #87111
07/11/08 08:11 AM
07/11/08 08:11 AM
Anonymous OP
Anonymous OP
Is there a source out there for original style pitman arm boots?
Mine is ripped and the only thing I can find is all rubber type boots that do NOT have the metal bushing in the center. that metal bushing is needed cause it seals the center of the boot to the pitman arm stud.
Re: Source for pitman arm boots #87112
07/15/08 12:35 PM
07/15/08 12:35 PM
Anonymous OP
Anonymous OP
I guess no one has these????
Re: Source for pitman arm boots- fixed it! #87113
07/21/08 10:25 AM
07/21/08 10:25 AM
Anonymous OP
Anonymous OP
So as i found, no one has these. at least nowhere I looked and I looked all over the place.
But I ended up fixing mine by cleaning them very well with lacquer thinner getting all the grease out. then a little bit of superglue and the splits were sealed up perfect!
Re: Source for pitman arm boots- fixed it! #87114
07/21/08 06:36 PM
07/21/08 06:36 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
While I don't have the part # available offhand, they are still available from Chrysler. I just bought one off of E-bay from Frederick Dodge.
