How many window trim holes in 69 B dutchman panel? #87104
07/11/08 08:03 AM
07/11/08 08:03 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
HELP! The shop that replaced the dutchman panel on my 69 RR did not drill any of the holes in it before they painted it. How many holes for the window trim clips are on this panel? I think theres 6, but I'd like to know for sure before I drill it.
Thanks,
Brent
Re: How many window trim holes in 69 B dutchman panel? [Re: NV69B7RR] #87105
07/11/08 10:26 AM
07/11/08 10:26 AM
Central, NY
DanMcG Offline
DanMcG  Offline
Central, NY
I got 8 on my 68. I'd guess they're the same
Dan
Re: How many window trim holes in 69 B dutchman panel? [Re: DanMcG] #87106
07/11/08 10:33 AM
07/11/08 10:33 AM
Central, NY
DanMcG Offline
DanMcG  Offline
Central, NY
here's a pic of 5 of the 8 if that helps. I could get some dimensions later if ya need them, dan
Re: How many window trim holes in 69 B dutchman panel? [Re: DanMcG] #87107
07/11/08 10:59 PM
07/11/08 10:59 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
The pic really helps, I can use the speaker tray area for a reference. Between that and the "ghosts" left on the window trim I can probably guess how it should be. Although any other pics would be a plus!
Thanks again.
Re: How many window trim holes in 69 B dutchman panel? [Re: NV69B7RR] #87108
07/12/08 06:16 AM
07/12/08 06:16 AM
Central, NY
DanMcG Offline
DanMcG  Offline
Central, NY
Here's a better pic and some measurements:
Measuring from the quarter/dutchman seam the first two holes are 2.1/4" and 6.1/4".
The two holes at the center of the panel are each 1 3/8" from center.
the remaining two holes are centered between the above two groups, but on mine one is dead center, and the other side is about 1 1/2" off center. (the one in the pic is off center)
Hope this helps.
Good luck, Dan
