727 leaking after warm up. #86977
07/10/08 09:24 PM
07/10/08 09:24 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
The trans leaks out the inspection cover after the car is warmed up and driven about 20 miles, and then quits leaking.It loses about a pint.I'm thinking bad torque converter seal,but someone said it might be overheating.The fluid is new&not burnt or over filled.Any ideas gentlemen?
Re: 727 leaking after warm up. [Re: Rosco] #86978
07/10/08 09:26 PM
07/10/08 09:26 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
It might be venting, are you sure it's not overfull??
MB
Re: 727 leaking after warm up. [Re: HPMike] #86979
07/10/08 10:12 PM
07/10/08 10:12 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
I always check it in neutral when it's warm.Wrong dipstick for the trans.possibly?
Re: 727 leaking after warm up. [Re: Rosco] #86980
07/10/08 11:26 PM
07/10/08 11:26 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I'm thinking seal, and pump bushing
