Page 23 of 81 1 2 21 22 23 24 25 80 81
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #868179
01/27/12 10:31 PM
01/27/12 10:31 PM
Queensland, Australia
Hemiken Offline
Hemiken  Offline
We did. We modified castings slightly. We are also vacuum resin sealing the cases now just to make sure!
That is good to hear
Have you figured out a final price for these yet please ?
Have you got a breakdown of costs, or an itemized list..... Thanks so much, great to see you are nearly there
Re: New Passon Performance 5 Speed update [Re: Hemiken] #868180
01/27/12 10:54 PM
01/27/12 10:54 PM
Castle Rock, CO
W
wegner426 Offline
wegner426  Offline
W
Castle Rock, CO
Jamie.......will you be taking TKO600's on trade?
Re: New Passon Performance 5 Speed update [Re: wegner426] #868181
01/29/12 10:03 PM
01/29/12 10:03 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Jamie, my convertible is still waiting...
I can't wait, I'll finally be able to afford to drive to Carlisle again
Re: New Passon Performance 5 Speed update [Re: wegner426] #868182
01/30/12 12:52 PM
01/30/12 12:52 PM
Sugarloaf, PA. USA
JamiePasson Offline OP
Sugarloaf, PA. USA
Wegner,
I would love to, but my boat already has a device to keep it stationary in one spot. Thanks for asking though!
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: New Passon Performance 5 Speed update [Re: MattW] #868183
01/30/12 12:55 PM
01/30/12 12:55 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Matt,
We have sold quite a few road course A-833 units to people. Mostly for use over in Europe. Customers have been very happy. We use our aluminum case and a 2.47 23 spline gearset.
Re: New Passon Performance 5 Speed update [Re: Hemiken] #868184
01/30/12 12:58 PM
01/30/12 12:58 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Hemiken,
The cost for the unit is going to be $4295.00 including shifter mechanism and linkage. I'm not sure what type of an itemized list you are looking for. Are you talking like:
Main Case: $XXX.00
Cluster gear: $XXX.00
etc.
Jamie
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #868185
01/30/12 02:21 PM
01/30/12 02:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #868186
01/30/12 09:32 PM
01/30/12 09:32 PM
Hemiken Offline
Hemiken  Offline
Hemiken,
Main Case: $XXX.00
etc.
Jamie
Hi Jamie,
What i meant was how much for the gear box, how much for the shifter to suite the 5 speed, how much for the bell housing, how much for the clutch assembly, etc, etc.
How much for a complete unit and what comes with it
Thanks mate,
Kenny.
Re: New Passon Performance 5 Speed update [Re: Hemiken] #868187
01/30/12 10:49 PM
01/30/12 10:49 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
He said the price was for the transmission, shifter and linkage. If you need other parts the price will depend on what parts you choose. You can find prices on his web site.
Hemiken,
Main Case: $XXX.00
etc.
Jamie
Hi Jamie,
Thanks mate,
Kenny.
Re: New Passon Performance 5 Speed update [Re: @#$%&*!] #868188
01/30/12 11:56 PM
01/30/12 11:56 PM
Ozone Park , New York
CudaJames Offline
CudaJames  Offline
If I understand correctly - if you already have a 4spd in the car all you would need is the trans , mechanism & shifter .
Should bolt right in . Maybe a clucth since it's apart .
70 Challenger Convert , 70 Barracuda 383 Convertible Project (USCarTool.com), 71 Cuda 340 project , 72 340 4spd Barracuda project , 69 Fury III Convertible project ,82 Ramcharger Cummins Conversion project , 1971 Demon - Father/Son project , '19 RedEye
Re: New Passon Performance 5 Speed update [Re: CudaJames] #868189
01/31/12 09:09 AM
01/31/12 09:09 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I believe you need to have an 18 spline set up already....
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #868190
01/31/12 02:37 PM
01/31/12 02:37 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Matt,
That sounds cool!
What else makes an 833 a "road course" tranny, other then gears/alum case mentioned above?
Not sure if address previously, can you install or are their provisions for lube external cooling ports in the 5 spd for road course apps?
Re: New Passon Performance 5 Speed update [Re: jcc] #868191
02/01/12 09:37 AM
02/01/12 09:37 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Torture testing Passon Performance Products
ummm I just ran a check of my log book
1000 track miles on the Passon alum case 4 sp overdrive and 750 track miles of Passon alum case 2.66 1st gear 4 speed. Another 750 track miles of an iron case 2.66 1st gear Passon 4 speed
Speeds range between 70-130 mph, time under duress 50 minutes per session 4x/day/2 days, no problems, no temp issues, no issues period, no vibration, just lots of fun.
Track is 3.4 miles
1000 miles is 294 laps...
750 miles is 221 laps
Everyone please be patient with the process of creating the the best 5 speed transmissions. Jamie will not release the beast until it's 101 percent right.
Unlike others in the business the Passon products work because:
Quality goes in before the name goes on.
Quality and integrity will be remembered long after the price is forgotten.
Re: New Passon Performance 5 Speed update [Re: ThermoQuad] #868192
02/01/12 08:18 PM
02/01/12 08:18 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Track is 3.4 miles
Shifts per lap?
Re: New Passon Performance 5 Speed update [Re: jcc] #868193
02/02/12 08:26 AM
02/02/12 08:26 AM
ThermoQuad Offline
ThermoQuad  Offline
3-4 front straight
4-3 to the esses
3-4 middle of the esses
End of back straight 4-3
hold 3d till toe of the boot
3-2 into toe
2 thru the toe, hold on for the six pak hit
2/3/4 coming out of toe up the hill
4-3 at top of hill hold till front straight
Track is 3.4 miles
Total laps is 736
7 shifts per lap
5152 shifts
Enough data for torture??
Re: New Passon Performance 5 Speed update [Re: @#$%&*!] #868194
02/02/12 09:31 AM
02/02/12 09:31 AM
Hemiken Offline
Hemiken  Offline
Hemiken,
Main Case: $XXX.00
etc.
Jamie
Hi Jamie,
Thanks mate,
Kenny.
Hey Drag Stripper,
You think my eyes are painted on or something mate, it is called an explanation to what he asked; I'm not sure what type of an itemized list you are looking for.
How about you stick your nose somewhere else and read before you post replies, i wasn't asking you anything. I was talking to Jamie and he cleared it up...............
Re: New Passon Performance 5 Speed update [Re: Hemiken] #868195
02/02/12 02:05 PM
02/02/12 02:05 PM
Thigh-Gap Junction
@#$%&*! Offline
@#$%&*!  Offline
Thigh-Gap Junction
Hey Ken, if you'd bothered to read the entire thread you wouldn't be asking stupid questions and being a pest. You've got a PM!
Re: New Passon Performance 5 Speed update [Re: @#$%&*!] #868196
02/02/12 08:40 PM
02/02/12 08:40 PM
Hemiken Offline
Hemiken  Offline
I read the lot and with extra work and fine tuning of parts - R&D, comes extra costs involved in production. Which can lead to extra cost for the consumer. Your PM was pathetic.
Sorry Jamie, back to your progress now buddy
Re: New Passon Performance 5 Speed update [Re: MattW] #868197
02/08/12 02:13 AM
02/08/12 02:13 AM
Oakley CA
69charger440_6pa Offline
Oakley CA
So if I'm reading correctly you are planning to release sometime around may-June?
How long will the shift throw be? Shorter than stock I hope.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: New Passon Performance 5 Speed update [Re: 69charger440_6pa] #868198
02/08/12 04:50 PM
02/08/12 04:50 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
I am hoping before that, but that is a realistic time frame. The throw is MUCH shorter than stick. As a reference, with a factory '68-74 A Body handle. TOTAL throw from 1st to 2nd is 3 1/2 inches. This is a VAST improvement over stock.
