Page 3 of 81 1 2 3 4 5 80 81
Re: New Passon Performance 5 Speed update [Re: Jim_Lusk] #867779
12/02/10 07:56 AM
12/02/10 07:56 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Who do you think might be torture testing it?...I can't wait
Re: New Passon Performance 5 Speed update [Re: ThermoQuad] #867780
12/02/10 09:37 AM
12/02/10 09:37 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
That might be more appealing than rebuilding my 4 speed. 18 spline isn't a problem, I will buy a new disc and take the strength gain for that cost.
Re: New Passon Performance 5 Speed update [Re: SomeCarGuy] #867781
12/02/10 11:10 AM
12/02/10 11:10 AM
Sugarloaf, PA. USA
JamiePasson Offline OP
Sugarloaf, PA. USA
I will try to answer some of the questions I saw.
At this time, no 23 spline. If we do that, we are going to lower the torque capacity of the trans significantly. It just doesn't make sense to spend more money to tool up for a weaker design.
There are tapered rollers throughout the trans. Input shaft, mainshaft and cluster gear front and rear.
Gear Ratios are
2.64
1.92
1.40
1.00
.70
Weight is 105 lbs
Thanks,
Jamie
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867782
12/02/10 11:32 AM
12/02/10 11:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gear Ratios are
2.64
1.92
1.40
1.00
.70
Weight is 105 lbs
Thanks,
Jamie
Re: New Passon Performance 5 Speed update [Re: JohnRR] #867783
12/02/10 11:48 AM
12/02/10 11:48 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I remember from the previous post something about trading in your old 4 speed transmissions?
Is this still an option?
Looking forward to getting pricing on this tranny.
Re: New Passon Performance 5 Speed update [Re: KillerBee] #867784
12/02/10 12:19 PM
12/02/10 12:19 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
In most cases, it will not be an even trade, but we will do our best to help people out.
Jamie
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867785
12/02/10 12:32 PM
12/02/10 12:32 PM
Candler,NC / Myrtle Beach, SC
JDMopar Online content
JDMopar  Online Content
Jamie...thank you for taking the huge amount of time it must have taken to develop this new transmission alternative for us. I'll be interested in an A-body version. Will the new shifter accept stock looking handles for the 3 different body styles?
Re: New Passon Performance 5 Speed update [Re: JDMopar] #867786
12/02/10 01:00 PM
12/02/10 01:00 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
JD,
We will do you one better, the new shifter accepts YOUR stock handle. We are making the shifter in both tower arrangements to accept both press in and bolt on handles. So, you will re-use your handle. You can simply change the ball to a 5 speed ball or the lens in a pistol grip to a 5 speed pattern. OR, for stealth, you don't even need to change the ball or lens. Either way, it is YOUR choice. We are not ramming this down anyone's throat that you MUST use our handle at an additional cost.
We wanted to make this as easy as possible for people. Plus, if you just dropped the money on rechroming your handle, you didn't "waste" that money. You will still be able to use the handle. Now, if anyone doesn't have a handle, we can also provide one, but it is not necessary.
These little details just put this product head and shoulders above ANY other option out there as being a TRUE bolt in with NO Mods. So, you won't look like this guy in order to put the transmission in your car!
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867787
12/02/10 01:42 PM
12/02/10 01:42 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Jamie Thank you for making this!
Any idea on an A body version??
Re: New Passon Performance 5 Speed update [Re: NV69B7RR] #867788
12/02/10 02:19 PM
12/02/10 02:19 PM
Twin Cities, MN
MN-ScatPack Offline
MN-ScatPack  Offline
Twin Cities, MN
Awesome! Can't wait for pricing. May need one for my e-body this spring.
Re: New Passon Performance 5 Speed update [Re: NV69B7RR] #867789
12/02/10 02:57 PM
12/02/10 02:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did you miss this ?
Believe me,
I am going to hammer hard. It is of course Made in the USA. We are looking at initially making 100 units. These will be divided between A, B and E Body tails. I should have pricing pretty well finalized by the end of next week.
Re: New Passon Performance 5 Speed update [Re: NV69B7RR] #867790
12/02/10 03:26 PM
12/02/10 03:26 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
The picture IS of an A Body trans. That is the first one that we did.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867791
12/02/10 03:34 PM
12/02/10 03:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867792
12/02/10 04:39 PM
12/02/10 04:39 PM
SomeCarGuy Offline
SomeCarGuy  Offline
JD,
Sweet. Anything that can be done to lwer costs and make it easier for guys to afford by reusing stuff is a good thing. Should help get the volume up where it needs to be.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867793
12/02/10 05:31 PM
12/02/10 05:31 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Some of us would have been fine if you stopped right there........
I would have done the A-body first, too.
Re: New Passon Performance 5 Speed update [Re: Jim_Lusk] #867794
12/02/10 05:44 PM
12/02/10 05:44 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Jim,
Thats funny. To be honest, the reason the A Body tail was cast first is because that was the car that was apart to the right degree to put on the lift to use. If my Cuda was apart, we would have an E Body first. Sorry to deflate you A Body guys.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867795
12/03/10 12:27 AM
12/03/10 12:27 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
This is a cool thing Jamie . Now my dream of driving my A12 bee, coast to coast, with the 4.10 dana instead of a 8.75 with 3.23s, could be a reality. The 4.10s would feel like a 2.87 with your .70 overdrive gear. And the 4.56s in my street/strip 67 GTX would be a livable 3.19 for the ride on the highway
Re: New Passon Performance 5 Speed update [Re: 6PACMAC] #867796
12/03/10 01:00 AM
12/03/10 01:00 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
6pac,
PRECISELY why we did this. We realize that there is no way that you guys are cutting the floor on an original A12 car or any other original car for that matter to put a Tremec in it.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867797
12/03/10 01:33 AM
12/03/10 01:33 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
6pac,
and I'm stoked! I had planned on a PASSON 4 speed OD but now my Duster will be getting one of these for sure!
Re: New Passon Performance 5 Speed update [Re: ScottSmith_Harms] #867798
12/03/10 02:04 AM
12/03/10 02:04 AM
At a gas station near you
badblack68 Offline
badblack68  Offline
Now I can plan ahead. I will have to take the 4:56 geared dana that is in in my GTX and put it in my Charger. I will take the 3:54 geared dana that is in my Charger and put it into my GTX. (GTX in an automatic) The 18 spline in my 68 is freshly rebuilt with only 1800 miles on it. I'm anxious to know what the final cost will be for this new 5 speed box so i can decide if I want to trade in my 4 speed HEMI box. Thanks for the effort Jamie and keep us all posted.
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
