Re: Engine/trans shipping ?
[Re: dOc !]
#86664
07/10/08 02:02 AM
07/10/08 02:02 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Shipped a 400 block from the Carolina's to Los Angeles for $125.00 via Fowardair.com (a couple years ago) If you can get the seller to haul it to the airport it's the best way to go. I'm sure the rates have changed some but still a better way to go.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: dOc !]
#86668
07/10/08 02:44 AM
07/10/08 02:44 AM
Wow Steve ... how can these people justisfy these rates ? ..... I have a high 20 mpg diesel PU and I could go round-trip for almost what they want one-way....in your case.
How many other carriers did you check?
and how long would you be in business doing that?
check with DHL and see if they'll negotiate with you.
[Re: dOc !]
#86672
07/10/08 03:46 PM
07/10/08 03:46 PM
eshipping.com ask for Hunter they will email you the BOL and labels and bill you after it is delivered safe should be able to get that done $350-$400 range If you drop at the terminal and have customer PU at terminal it is better
[Re: ]
#86673
07/10/08 04:13 PM
07/10/08 04:13 PM
R70RUNNER
Riverside, Ca
440... Yep, just block and caps for me. Their specialty is shipping motorcycles. so bigger is no problem. has to be pallet-able. They even load and unload from a pickup truck at the dock so the shipper/receiver has little to but walk up and do paper work at the terminal. Super smooth. I've worked harder to get letters out of the Post Office
