Prestolite Dual Point - Broken Nylon Collar #86620
07/09/08 11:04 PM
07/09/08 11:04 PM
St. Louis, MO
DodgeMaterial Offline OP
St. Louis, MO
Anyone know where I can find the correct collar/pin set for my original dual point (prestolite) distributor? Mine is broken in two...this is the white nylon collar that is on the shaft at the base of the housing - held on by a roll pin. Thanks, Dave
DodgeMaterial - Dave JS29U0B - FK5 - 440-4 Auto WS23V0A - EB5 - 440-6 Auto
Re: Prestolite Dual Point - Broken Nylon Collar [Re: DodgeMaterial] #86621
07/10/08 12:52 PM
07/10/08 12:52 PM
Hummelstown, PA
AINTNRT Offline
AINTNRT  Offline
Hummelstown, PA
Do not know if they're the same but was able to buy a new one for the electronic ignition distributor from MOPAR.
Re: Prestolite Dual Point - Broken Nylon Collar [Re: DodgeMaterial] #86622
07/10/08 01:53 PM
07/10/08 01:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Never saw an origional Prestolite dual point with a plastic collar.If you want a steel one I can fix you up.
Re: Prestolite Dual Point - Broken Nylon Collar [Re: 62maxwgn] #86623
07/11/08 04:35 PM
07/11/08 04:35 PM
NY
Beep Beep Offline
Beep Beep  Offline
NY
I tried using an MP collar on my stock 69 RR distributor. Can't remember if it was plastic or metal, but when I tried using it I had to shim the bottom because the roll pin hole on the MP was in the center of the plastic collar. The stock one was of centered. You can shim it with some shim washers.
Re: Prestolite Dual Point - Broken Nylon Collar [Re: Beep Beep] #86624
07/11/08 04:39 PM
07/11/08 04:39 PM
If it's at all like the other distributors you can get a nylon collar at Lowes that is perfect. A roll pin can be had at the same place too. You will have to drill the hole in the nylon collar but you have to do that with the MP kit anyway.
Re: Prestolite Dual Point - Broken Nylon Collar #86625
07/14/08 09:45 AM
07/14/08 09:45 AM
St. Louis, MO
St. Louis, MO
All- Thanks for the excellent advise! This should allow me to have the old six pack warming the earth soon! Dave
