1969 dodge dart brake proportioning valve. #86595
07/09/08 10:49 PM
07/09/08 10:49 PM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Does anyone have a picture of one? I did't take the car apart so I don't know what it look's like or where it is mounted. How about where to buy one? Thank!!! Scott The car is a GTS,340,four speed, front disk, 10"rear drum, manual brakes
Re: 1969 dodge dart brake proportioning valve. [Re: IEAT4DS] #86596
07/09/08 10:55 PM
07/09/08 10:55 PM
Western Colorado
3
340Scamp Offline
340Scamp  Offline
Western Colorado
This is on my dad's '69 340 GTS with disc brakes.
Re: 1969 dodge dart brake proportioning valve. [Re: 340Scamp] #86597
07/09/08 11:01 PM
07/09/08 11:01 PM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Thanks for the picture. It is awesome. Where is that located? Thanks Again!!!
Re: 1969 dodge dart brake proportioning valve. [Re: 340Scamp] #86598
07/09/08 11:05 PM
07/09/08 11:05 PM
Western Colorado
3
340Scamp Offline
340Scamp  Offline
Western Colorado
another
Re: 1969 dodge dart brake proportioning valve. [Re: 340Scamp] #86599
07/09/08 11:20 PM
07/09/08 11:20 PM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Perfect. You are the best!!! That looks like a F8 green Dart. Green Rules!!!
Re: 1969 dodge dart brake proportioning valve. [Re: IEAT4DS] #86600
07/09/08 11:27 PM
07/09/08 11:27 PM
Western Colorado
3
340Scamp Offline
340Scamp  Offline
Western Colorado
Yea, He's almost got it finished.
Re: 1969 dodge dart brake proportioning valve. [Re: 340Scamp] #86601
07/10/08 01:09 AM
07/10/08 01:09 AM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Does anyone have an extra one to sell or know where to buy a new one? For some reason I can't post on parts wanted. Thanks!! Scott
Re: 1969 dodge dart brake proportioning valve. [Re: IEAT4DS] #86602
07/11/08 07:44 AM
07/11/08 07:44 AM
Burkesville Ky.
gerty Offline
gerty  Offline
Burkesville Ky.
Pm sent
Re: 1969 dodge dart brake proportioning valve. [Re: IEAT4DS] #86603
07/12/08 04:42 AM
07/12/08 04:42 AM
ne
broncobra Offline
broncobra  Offline
ne
Inline tube carries brand new Mopar ones.
Re: 1969 dodge dart brake proportioning valve. [Re: broncobra] #86604
07/13/08 08:48 PM
07/13/08 08:48 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
If you have disc brakes on the front, there is a proportioning valve between the brake line distribution block and the rear end. It is different than the photo shown and is called the proportioning valve. It mounts to the frame just where it starts to go under the front floorboard.
Re: 1969 dodge dart brake proportioning valve. [Re: RoadRunnerJD] #86605
07/14/08 05:43 PM
07/14/08 05:43 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Right, Here's a pic of that valve.
Re: 1969 dodge dart brake proportioning valve. [Re: GODSCOUNTRY340] #86606
07/14/08 07:24 PM
07/14/08 07:24 PM
Warrenton, VA
Warrenton, VA
I forgot about the bracket for it? Does anyone repro the bracket (box)?
Re: 1969 dodge dart brake proportioning valve. [Re: RoadRunnerJD] #86607
07/14/08 10:17 PM
07/14/08 10:17 PM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Thanks for all the info. I went to(Inline Tubes)web site. They said both the valves were used on a- bodies. They also make brackets for the Texas shaped valve. I wonder which valve they chose to use on my car? Thank You!!! Scott
Re: 1969 dodge dart brake proportioning valve. [Re: IEAT4DS] #86608
07/15/08 11:32 AM
07/15/08 11:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Why the ? The factory used both valves with disc brakes , the first picture is of a distribution block , no valving , the second is the proportioning valve .
The 71-72 A bodies with KH 4 piston had a combination distribution block proportioning valve (???) , I bought one over the weekend at Carlisle from Fine Lines , it eliminates the 2 piece rear line. I'm going to be trying it in a car I'm working on for a friend first and see how it works . I also have the valve from my dads 72 duster that I parted years ago to see if its the same piece ???
Re: 1969 dodge dart brake proportioning valve. [Re: JohnRR] #86609
07/15/08 03:41 PM
07/15/08 03:41 PM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Thanks Johnrr for clearing things up. I am a slow learner.Inline tube carries both the combination distribution/ proportioning valve and the two seperate piece set up (Part #blk245). I want the setup to be factory correct.I am going with your advice. I will be completing the brakes as soon as my parts come. The little green guy I posted looked like he was looking up at all the info for reference thats why I used him.
