Champion Spark Plugs #86498
07/09/08 09:32 PM
07/09/08 09:32 PM
MI
AfterHoursResto Offline OP
MI
Whats the difference between RJ12YC and RC12YC and RC12YC5?
Thanks.
Roman Sobilo
Re: Champion Spark Plugs [Re: AfterHoursResto] #86499
07/09/08 09:44 PM
07/09/08 09:44 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
First off the R at the front of that stands for Resistor. The 12 is the heat range the Y is for the 13/16" wrench it takes I believe off hand and the C is for copper. Now the J and the C in front of the 12 on all 3 stands for the threads and length of the the tip. The only Mopar plug of them is the RJ12YC which is a Big Block plug with a decent heat range for a street or street/strip car.
Re: Champion Spark Plugs [Re: mopowergtx] #86500
07/09/08 10:01 PM
07/09/08 10:01 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
r=resistor
j=13/16 hex, 14mm thread, 3/8 reach,
c=5/8 hex, 14mm thread 3/4 reach
12=heat range
y=extended tip
c=copper electrode
pretty sure i'm right
