Tranny length 904 & 727 #86313
07/09/08 01:25 PM
07/09/08 01:25 PM
Hightstown, NJ
njdevil2 Offline OP
njdevil2  Offline OP
Hightstown, NJ
I'm taking my 360/727 from my Aspen wagon and going to put it in my '73 Satellite 318/904. Is there going to be a tranny mounting problem? Is the 727 longer than the 904?
Thanks for any help I can get!!
1970 road runner Convertible
1 of 179
Re: Tranny length 904 & 727 [Re: njdevil2] #86314
07/09/08 01:32 PM
07/09/08 01:32 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
If it's the original 727 to the Aspen, yes, it will be too short in the Satellite. A/F tailshafts are shorter on all manual and automatic transmissions.
Re: Tranny length 904 & 727 [Re: njdevil2] #86315
07/09/08 01:33 PM
07/09/08 01:33 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
the 904 will bolt up just fine, but you will need a longer drive shaft , I used one from a 6/904 combo in my corronet..sorry i do not know the correct legnth of the shaft or the trans but the 727 is a bit longer
Re: Tranny length 904 & 727 [Re: Dakota_Don] #86316
07/09/08 02:32 PM
07/09/08 02:32 PM
Norway
Dart270 Offline
super gas
Dart270  Offline
super gas
Norway
The 727 is 4" longer than a 904 trans.
360/300 Crate Magnum, Ram Air filter box, 727TF, 8-1/4 suregrip,Rally susp., Koni shocks, 0.92 T-bar, 1.25 fr. & 7/8 rear sway bar. Moog offset bushings, 73 front disk, TTI headers&exhaust, AAR fiberglass Hood, Firm Feel K-member, Stage 2 PS.
Re: Tranny length 904 & 727 [Re: Dart270] #86317
07/09/08 03:22 PM
07/09/08 03:22 PM
Hightstown, NJ
njdevil2 Offline OP
njdevil2  Offline OP
Hightstown, NJ
The 727 is a '67 housing, was previously in my '71 Dodge Demon with 360, went to the Aspen w/360.
SO< I'll have to get another tranny for this deal?
1 of 179
Re: Tranny length 904 & 727 [Re: In_The_Pink] #86318
07/09/08 03:47 PM
07/09/08 03:47 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Wrong answer. All 727's are the same length and all 904's the same length and both use the same tail housing mount location until you start talking 4X4 truck or extended wheel base trucks and vans with split drive shafts.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Tranny length 904 & 727 [Re: MoparforLife] #86319
07/09/08 04:03 PM
07/09/08 04:03 PM
Hightstown, NJ
njdevil2 Offline OP
njdevil2  Offline OP
Hightstown, NJ
Sweet....if that is true, then I don't have to get another tranny. I'm not really worried about drive shaft length. Between the two I have, if it don't fit, there is always CUSTOM .
Thanks for the help.
I suspected it may be ok, the 727 went into the Aspen (where the original /6 904 resided) like a glove.
1 of 179
Re: Tranny length 904 & 727 [Re: njdevil2] #86320
07/09/08 07:05 PM
07/09/08 07:05 PM
Upper Midwest
Upper Midwest
yes the 727 is longer but the length difference is in the tail shaft after the mount.
