Cuda will only run with key held short of start #86298
07/09/08 11:38 AM
07/09/08 11:38 AM
Illinois
74_cuda Offline OP
74_cuda  Offline OP
Illinois
My 74 cuda will stay running with the key held but as soon I let it go to run it dies.
I replaced the ballast resister with a new one, so it appears to be the ignition switch.
Before I tear the column apart could anything else be causing the problem?
Re: Cuda will only run with key held short of start [Re: 74_cuda] #86299
07/09/08 11:57 AM
07/09/08 11:57 AM
Kirkland, Washington
Pacnorthcuda Offline
yes, the ignition power feed through the bulkhead connector. These connections are now over 30 years old and failing fast. Clean the connection as best possible and reattach. You can confirm that you have 12 volts feeding INTO the connection from under the dash with the ignition in the run position. On my 70 cuda the connection is the in the first vertical row closest to the steering column, second from the bottom. Your's may be different. I ran a completely separate bypass to eliminate the need for this critical connection entirely, but you may not be willing to make that mod.
Re: Cuda will only run with key held short of start [Re: Pacnorthcuda] #86300
07/10/08 12:06 PM
07/10/08 12:06 PM
Illinois
74_cuda Offline OP
74_cuda  Offline OP
Illinois
Well I pulled the bulkhead connector to check the connections.
Small meltdown in cavity 23 (run). Looks like I'll need to replace the blade and reattach the wire in the bulkhead to fix.
My question what could have caused this?
Re: Cuda will only run with key held short of start [Re: 74_cuda] #86301
07/10/08 12:13 PM
07/10/08 12:13 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Resistance, bad ground or a loose connection can cause resistance (a short will cause low resistance, excessive amp dram and blow the circuit or burn it up). Resistance can cause the circuit to get hot.
How did I do?
