B body hoods #86074
07/08/08 09:38 PM
07/08/08 09:38 PM
Santa Fe,Texas
TexasMopar Offline OP
Santa Fe,Texas
Are 68 RR and 69 RR hoods interchangeable? Same size and fit. Thanks for any replies. Jim
Re: B body hoods [Re: TexasMopar] #86075
07/08/08 09:46 PM
07/08/08 09:46 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
The hoods will bolt on but the location of the latches is different.
Re: B body hoods [Re: TooMany62s] #86076
07/08/08 09:54 PM
07/08/08 09:54 PM
Santa Fe,Texas
Santa Fe,Texas
Can you change out the hood latches to make them work?
Re: B body hoods [Re: TexasMopar] #86077
07/08/08 10:10 PM
07/08/08 10:10 PM
DFW
68RRFlyer Offline
68RRFlyer  Offline
DFW
If I'm not mistaken, the later 68s were the same as the 69s in regrads to the mounting points. My July 4th Build 68 RR has the 69 latch mount. And it's the original hood. I think the change over was February or so. Not exactly sure. Myabe someone else who knows more (A12) can reply.
Cheers
