Page 15 of 26 1 2 13 14 15 16 17 25 26
Re: 71 cuda pro touring project [Re: Golden-Arm] #860114
06/11/12 10:23 AM
06/11/12 10:23 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
That license plate slider is really trick! Again, your level of fabrication is amazing, keep up the great work!!
Re: 71 cuda pro touring project [Re: Golden-Arm] #860115
06/22/12 08:28 PM
06/22/12 08:28 PM
Mrytle Beach SC
johnscudashop Offline OP
Mrytle Beach SC
i sunk the battery box down into the trunk floor to keep it from moving around, to keep the weight as low as possible, and to gain some trunk space.
Re: 71 cuda pro touring project [Re: johnscudashop] #860116
06/22/12 08:30 PM
06/22/12 08:30 PM
Mrytle Beach SC
Mrytle Beach SC
I couldnt find a holddown bracket that I was happy with so I made one from Aluminum that forms to the top of the batery box.
Re: 71 cuda pro touring project [Re: johnscudashop] #860117
06/22/12 08:32 PM
06/22/12 08:32 PM
Mrytle Beach SC
Mrytle Beach SC
I used to stainless rods and thread the ends . These are bolted directly to the trunk floor.
Re: 71 cuda pro touring project [Re: NV69B7RR] #860118
07/02/12 01:37 PM
07/02/12 01:37 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
WOW lot of Work...good build
Re: 71 cuda pro touring project [Re: 70blackfish] #860119
07/07/12 07:35 PM
07/07/12 07:35 PM
Mrytle Beach SC
Mrytle Beach SC
Because I set the driveline angle to 1 deg down as apposed to 3 deg down I had a issue with the TTI headpipes hitting the floor. not to disturb or ajust the pipes in any way, I sectioned part of the floor over the pipes
Re: 71 cuda pro touring project [Re: johnscudashop] #860120
07/11/12 04:23 PM
07/11/12 04:23 PM
Mrytle Beach SC
Mrytle Beach SC
Floor welded up
Re: 71 cuda pro touring project [Re: johnscudashop] #860121
07/20/12 05:24 AM
07/20/12 05:24 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Incredible.
I can't afford this. mark
Re: 71 cuda pro touring project [Re: a12superbee] #860122
07/20/12 07:55 PM
07/20/12 07:55 PM
Mrytle Beach SC
Mrytle Beach SC
I proceeded remove the drip rail gutters.Because the pinch weld will be removed the roof will come loose from the car,So What I did is cut 2 inch sections at a time. Leaving the roof attached, I added a good tack weld between the sections ,then cut the rest of the roof rail sections off.
Re: 71 cuda pro touring project [Re: johnscudashop] #860123
07/20/12 07:56 PM
07/20/12 07:56 PM
Mrytle Beach SC
Mrytle Beach SC
Roof rail removed
Re: 71 cuda pro touring project [Re: johnscudashop] #860124
07/20/12 08:01 PM
07/20/12 08:01 PM
Mrytle Beach SC
Mrytle Beach SC
With the window channel in place, I made some aluminum brackets to hold the rear quarter windows in place. Like a coupe.I plan on only power windows for the front.
Re: 71 cuda pro touring project [Re: johnscudashop] #860125
07/20/12 08:02 PM
07/20/12 08:02 PM
Mrytle Beach SC
Mrytle Beach SC
inside veiw
Re: 71 cuda pro touring project [Re: johnscudashop] #860126
07/21/12 07:25 PM
07/21/12 07:25 PM
Mrytle Beach SC
Mrytle Beach SC
I added universal power door lock kit,I thought it would be a neat addition. .These are available on Ebay for $20 or so I made some aluminum blocks to mount it to. I didn't like the metal mounting strips that came with the kit.
Re: 71 cuda pro touring project [Re: johnscudashop] #860127
07/21/12 07:27 PM
07/21/12 07:27 PM
Mrytle Beach SC
Mrytle Beach SC
Picure,With latch rod added
Re: 71 cuda pro touring project [Re: johnscudashop] #860128
07/27/12 06:29 PM
07/27/12 06:29 PM
Mrytle Beach SC
Mrytle Beach SC
I took a challenger trunk latch and 68 Imperial remote trunk mechinism and modufied it to fit the cuda. Now I can weld up the trunk lock hole. I plan on a cable to pop the trunk just in case of emergency.
Re: 71 cuda pro touring project [Re: johnscudashop] #860129
08/04/12 12:14 PM
08/04/12 12:14 PM
Mrytle Beach SC
Mrytle Beach SC
Added a shaved door handle kit from Electric Life. Mounted the door poppers in the door.
Re: 71 cuda pro touring project [Re: johnscudashop] #860130
08/04/12 12:15 PM
08/04/12 12:15 PM
Mrytle Beach SC
Mrytle Beach SC
Door popper mounting
Re: 71 cuda pro touring project [Re: johnscudashop] #860131
08/04/12 12:17 PM
08/04/12 12:17 PM
Mrytle Beach SC
Mrytle Beach SC
Modified the door latches to accept a extra hole for the pull cable to go thru
Re: 71 cuda pro touring project [Re: johnscudashop] #860132
08/06/12 03:15 PM
08/06/12 03:15 PM
Mrytle Beach SC
Mrytle Beach SC
I mounted some spring loaded plungers to the inside of the door jambs so when the door popper pulls the latch that the heavy cuda door pops out
Re: 71 cuda pro touring project [Re: johnscudashop] #860133
08/16/12 04:12 PM
08/16/12 04:12 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
John,
I haven't been following the build lately. Very nice progress and some remarkable features!
Ray
