Visual differences between converters? #85968
07/08/08 05:58 PM
07/08/08 05:58 PM
a cornfield near you
BlakDak Offline OP
BlakDak  Offline OP
is there a way to visually tell the difference between a lock up and non lock up converter?
or does any one know where I can look up the part numbers?
Re: Visual differences between converters? [Re: BlakDak] #85969
07/08/08 06:07 PM
07/08/08 06:07 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
There is a difference when you look into the converter, But I don't have the two converters here to look at. I can tell you that the lockup coverter is a good bit heavier though. Maybe John Kunkel will chime in.
Re: Visual differences between converters? [Re: dmerc] #85970
07/08/08 08:08 PM
07/08/08 08:08 PM
BlakDak Offline OP
BlakDak  Offline OP
any one in the evening crowd?
Re: Visual differences between converters? [Re: BlakDak] #85971
07/09/08 06:13 PM
07/09/08 06:13 PM
BlakDak Offline OP
BlakDak  Offline OP
bueller?
Re: Visual differences between converters? [Re: BlakDak] #85972
07/10/08 03:02 PM
07/10/08 03:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When looking into the converter, the larger first set of splines is the stator, the smaller second set of splines is the turbine; a non-lockup will have what looks like a flat bulkhead past the turbine splines, a lockup will have an additional bore with a bushing past the turbine splines.
If the converter has a drain plug it isn't lockup, if it's a 12" converter it isn't lockup.
Re: Visual differences between converters? [Re: John_Kunkel] #85973
07/10/08 04:26 PM
07/10/08 04:26 PM
BlakDak Offline OP
BlakDak  Offline OP
bah, so I have to empty everyone till I find one!....
Re: Visual differences between converters? [Re: BlakDak] #85974
07/10/08 07:11 PM
07/10/08 07:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most, if not all, LU converters left the factory with a round sticker identifying them as such; you might get lucky and still be able to find/read the sticker.
