Re: Opinion of Engle cams?
[Re: Triggerfish]
#85870
07/08/08 04:56 PM
07/08/08 04:56 PM
Posts: 74,904 U.S.S.A.
JohnRR
U.S.S.A.
Just ordered a Hyd flat tappet cam for my 451 stroker from Engle Cams. Is anyone running their cam & what's your opinion of it?
i got one, a std grind solid with a modifed spec, but never ran it .
dumb question , shouldn't you have asked this BEFORE ordering ???
[Re: Triggerfish]
#85871
07/08/08 05:03 PM
07/08/08 05:03 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I have one in the Hemi and I like it. One of the better cam companies in my opinion. Very knowledgeable and very accessible by phone if you have any questions.
[Re: JohnRR]
#85874
07/08/08 06:39 PM
07/08/08 06:39 PM
do you ask your server for a sample of the steak your about to order too?
[Re: Redbird]
#85879
07/09/08 12:06 AM
07/09/08 12:06 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Back in the 80s I built a couple of Hemis with the K7 Hyd cams somewhere around .550 lift and was very happy with the results. My current motor has a slightly custom K5 Hyd with around 520 and 109 , I havent driven this one yet but it sounds really strong.. I have been using Crower Hyd pushrods with them..
#85880
07/09/08 12:15 AM
07/09/08 12:15 AM
JohnRR
U.S.S.A.
so you changed your username so you can hide while acting like a moron ...
good work
[Re: Triggerfish]
#85881
07/09/08 12:17 AM
07/09/08 12:17 AM
JohnRR
U.S.S.A.
Thanks for the info. I put trust in a friend's advice whose a reputable Mopar builder & has built some great motors that made good power w/ the Engle cams & your recommendations verified his prefrence for Engle. Got a flat tappet 504/514 lift intake/exhaust & 272/280 duration on a 112 lobe separation. Should run well in a 451 stroker. Doug @ engle was really helpful.
i ordered the K1 grind with the lobe sep at 112 for my then 432 stroker build , except i got a solid flat tappet
good cam choice .
[Re: R70RUNNER]
#85882
07/09/08 12:36 AM
07/09/08 12:36 AM
Posts: 7,051 Madera, CA.
MowP4rsn
Madera, CA.
Engle grinds Bob K's Mr. Sixpack cams. Pleased with the cam all the way around.
Yup, that's what mine sez on it
[Re: JohnRR]
#85883
07/09/08 12:52 AM
07/09/08 12:52 AM
made in china no doubt.
#85884
07/09/08 12:54 AM
07/09/08 12:54 AM
JohnRR
U.S.S.A.
you replied before igot my edit thru
[Re: JohnRR]
#85885
07/09/08 12:57 AM
07/09/08 12:57 AM
what can i say cept' i had a obtuse flotsam moment...
#85886
07/09/08 09:11 AM
07/09/08 09:11 AM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
I have an Engle K54 cam in my 440. Very streetable yet aggressive when it counts
1MYTGTX
[Re: dwbiggs]
#85888
07/09/08 12:56 PM
07/09/08 12:56 PM
Posts: 2,507 Royersford, PA
bschargerse
Royersford, PA
I notice they only sell one dual pattern cam on their website for BB Mopars, and it's a smaller one, bummer. I prefer a dual pattern cam, for some odd reason.
Brian - 1971 Dodge Challenger "The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
