cap auto dynamic struts #858689
11/20/10 07:17 PM
11/20/10 07:17 PM
DANBURY CT
fury62 Offline OP
fury62  Offline OP
DANBURY CT
just wondering if anyone is using cap auto products dynamic struts compared to other brands like RMS.it looks like the rms has polly bushings and the caps don't show bushings. do they bolt up solid to the k frame?? any suggestions. thanks john
Re: cap auto dynamic struts [Re: fury62] #858690
11/20/10 09:39 PM
11/20/10 09:39 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I believe the RMS ones on OU812's car were aluminum K frame bushings.
Re: cap auto dynamic struts [Re: RobX4406] #858691
11/20/10 09:46 PM
11/20/10 09:46 PM
okla.
sam64 Offline
sam64  Offline
okla.
the rms are aluminum for the bushing end,just installed a set on my 63 belvedere.
Re: cap auto dynamic struts [Re: sam64] #858692
11/20/10 09:49 PM
11/20/10 09:49 PM
DANBURY CT
fury62 Offline OP
fury62  Offline OP
DANBURY CT
your saying rms has no polly bushings?
Re: cap auto dynamic struts [Re: fury62] #858693
11/20/10 09:52 PM
11/20/10 09:52 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
EXACTLY......I've used a BUNCH of them.....aluminum bushings with heim joints......
If you can't handle the truth, you're living a lie.......
Re: cap auto dynamic struts [Re: Big Squeeze] #858694
11/20/10 09:56 PM
11/20/10 09:56 PM
DANBURY CT
fury62 Offline OP
fury62  Offline OP
DANBURY CT
RMS web site shows polly bushings that attach to the k frame is that correct?
Re: cap auto dynamic struts [Re: fury62] #858695
11/20/10 10:02 PM
11/20/10 10:02 PM
RobX4406 Offline
RobX4406  Offline
Yes they are poly...
please note sarcasm...
Maybe you should call him Bill Reilly at RMS on monday and ask.
You got three answers of aluminum from people that have seen and installed more than three sets... so they miust be poly!
Re: cap auto dynamic struts [Re: RobX4406] #858696
11/20/10 10:06 PM
11/20/10 10:06 PM
RobX4406 Offline
RobX4406  Offline
Here's a direct quote from the instructions...
Install solid bushing kit into k-frame. Be sure the clevis - rod-end attaching bolt is tightened prior to installation. Leave bushing nut loose enough that the assembly can be rotated slightly in the K-frame for alignment afterward.
I don't see anything mentioning poly on his site in the sales section. Maybe you are assuming the bushings on the strut rods in the picture are poly?
Re: cap auto dynamic struts [Re: RobX4406] #858697
11/20/10 10:08 PM
11/20/10 10:08 PM
okla.
sam64 Offline
sam64  Offline
okla.
the aluminum bushings are black so you might think they are rubber.
Re: cap auto dynamic struts [Re: RobX4406] #858698
11/20/10 10:15 PM
11/20/10 10:15 PM
DANBURY CT
fury62 Offline OP
fury62  Offline OP
DANBURY CT
thanks,just trying to get a heads up on which product to use.
Re: cap auto dynamic struts [Re: sam64] #858699
11/20/10 10:17 PM
11/20/10 10:17 PM
DANBURY CT
fury62 Offline OP
fury62  Offline OP
DANBURY CT
yes your right they do look like polly
