Re: 1973 Duster wirnig issues...Help [Re: firtdog] #858676
11/21/10 05:02 PM
11/21/10 05:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check for power at the brake light switch. Push the pedal and see if you have power at both sides of the switch. For the trun signals make sure you have power at the flasher. It feeds the switch. You will have two flashers. One for the T/S and one for the emergency lights.
Re: 1973 Duster wirnig issues...Help [Re: stumpy] #858677
11/21/10 05:13 PM
11/21/10 05:13 PM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
I have emegency light power but when i flip the turn signal it doesnt even tick. Where do I find the switch for the turn signal. I get no power for the brakes
Re: 1973 Duster wirnig issues...Help [Re: firtdog] #858678
11/21/10 05:17 PM
11/21/10 05:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try up around the radio or steering column. If you have no brake lights check your fuses. I thought you said eariler you had a wiring diagram?
Re: 1973 Duster wirnig issues...Help [Re: stumpy] #858679
11/21/10 06:19 PM
11/21/10 06:19 PM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
I do have the wiring diagram, but it throws me off a little. Found the stopo switch have power on one side but not on the other even when pushing the peddle. Bought a new switch because the lights light up when I jump the wires. I hope this works...
Re: 1973 Duster wirnig issues...Help [Re: firtdog] #858680
11/21/10 09:40 PM
11/21/10 09:40 PM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
Well I have the lights working:hl, tl, sml and replaced the stop switch and the brake lights work now. Thanks for all your help guys. Now I work on the blinkers. I have hazard lights but no turn signals. I got the turn signal switch and assume I must take the steering wheel apart??????
Re: 1973 Duster wirnig issues...Help [Re: firtdog] #858681
11/21/10 09:50 PM
11/21/10 09:50 PM
yes. Rent a puller
Re: 1973 Duster wirnig issues...Help [Re: RapidRobert] #858682
11/22/10 01:05 AM
11/22/10 01:05 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you check for power at the turn signal flasher? Remember there are two different flashers on your car. If you don't have power then replacing the switch is a waste of time.
Re: 1973 Duster wirnig issues...Help [Re: stumpy] #858683
11/22/10 01:32 AM
11/22/10 01:32 AM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
Where on the diagram is that?
Re: 1973 Duster wirnig issues...Help [Re: stumpy] #858684
11/22/10 09:02 PM
11/22/10 09:02 PM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
I got power to the flasher, but I still dont have the turn signals. When I turn on the hazards they flash but not when I turn on the turn signals.
Re: 1973 Duster wirnig issues...Help [Re: firtdog] #858685
11/22/10 09:58 PM
11/22/10 09:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you sure you have the right flasher? The one that you have power to does it click when you turn the emergency lights on. If it does then you need to keep looking until you find the other one and see if it has power.
Re: 1973 Duster wirnig issues...Help [Re: stumpy] #858686
11/22/10 10:02 PM
11/22/10 10:02 PM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
Yeah I finally figured out the diagram. I was testing the wrong one. Thanks. I will find it shortly and test it.
Re: 1973 Duster wirnig issues...Help [Re: stumpy] #858687
11/22/10 10:44 PM
11/22/10 10:44 PM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
Thanks alot, you just saved me a load of work. I found the plug it was under the glove box, and it didnt even have a flasher in it. all the lights are working good. Thanks again. This is probally the best website I have ever found!!!
Re: 1973 Duster wirnig issues...Help [Re: firtdog] #858688
11/22/10 11:03 PM
11/22/10 11:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Glad you got everything working.
