HEMI ROCKERARM ADJUSTMENT #85818
07/08/08 03:20 PM
07/08/08 03:20 PM
Chesterfield, MIch
Cuda67 Offline OP
super street
Cuda67  Offline OP
super street
Chesterfield, MIch
Hi
Thanks for any response. I just bought a car with a Hemi. I know very little about the Hemi. It has a 572/272 Comp cam. 472 ci with 11.5 compression. Also has aluminum heads. I need to adjust the Hartland roller rockers. What are the spec's and any help you might be able to give me. I screwed around with cars along time ago, so I do have some knowledge.
Thanks Again
Ray
Re: HEMI ROCKERARM ADJUSTMENT [Re: Cuda67] #85819
07/08/08 05:08 PM
07/08/08 05:08 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Hi
Thanks Again
Ray
Same rules apply as a wedge. Is it hydraulic or solid. I find the best way is to do each cylinder one at a time. Roll over the engine until the exhaust valve just opens, set the intake lash (or pre load). Roll it over somemore until the intake valve opens and is just about closed. Adjust the exhaust valve. With a hydraulic, about 1/2 turn of preload from zero lash should do it.
Re: HEMI ROCKERARM ADJUSTMENT [Re: Cuda67] #85820
07/08/08 06:12 PM
07/08/08 06:12 PM
Chesterfield, MIch
Cuda67 Offline OP
super street
Cuda67  Offline OP
super street
Chesterfield, MIch
It is the 572/272 solid cam.
Re: HEMI ROCKERARM ADJUSTMENT [Re: Cuda67] #85821
07/08/08 06:18 PM
07/08/08 06:18 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Ok, then you wont need the preload part. Set the lash to the cam spec. If its not a tight lash cam, then .028" on the intake and .028-032" on exhaust should be OK.
Re: HEMI ROCKERARM ADJUSTMENT [Re: torkrules] #85822
07/08/08 06:33 PM
07/08/08 06:33 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
comp cam solid is 26/26 lash on both sides
MOPAR OR NO CAR
Re: HEMI ROCKERARM ADJUSTMENT [Re: hemigod426] #85823
07/08/08 07:14 PM
07/08/08 07:14 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
